Air Baffle Plate Fitment Issue, On a 2056 Build |
BeatNavy |
Mar 27 2019, 02:13 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Trying to wrap up my 2056 build off of a 1.7 case. Has anyone had an issue getting the air baffle plates to fit with the 96mm cylinders? These are the little cooling tin pieces tucked under the cylinders on both sides. The 3/4 one seems to fit, but the 1/2 piece, which I know is different, will not. The "ribs" on the piece are interfering a bit with the cooling fins on the cylinders. I'm happy to grind the tin down a bit to get it to fit, but I'm hoping this isn't an indicator that I've done something else wrong in terms of assembly.
I DID have .035" shaved off the bottom of the cylinders to get proper deck height, and I can see where that may have contributed. I believe the baffle pieces are unique L/R but are the same across all years. TIA (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 12:07 AM |
