> FIXED: Idle weirdness, FIXED: Need a sanity check
ctc911ctc
post Mar 31 2019, 11:29 AM
All,
I posted this solution in another related post - wanted to close this one out.
**************PROBLEM SOLVED************
Picked up this car in October 2018,
I have fixed 100+ problems, some are listed below. I believe it is NOW ready for the road, it has not been registered since 1984.
When I pulled the Plenum (chasing the too rich issue) I was able to remove the CHT. Could not get a wrench on it prior. I replaced it. As I wrote above; after I got the fixed plenum back into the car, the idle adjustment screw had no effect. This according to the all knowing Anders, is the result of a car running too lean. which also caused the popping....
So I went back to the old CHT (I had not tested it, just changed it because of it's age and it is on near everyone's list of things to replace) and I found that it was open - No Good. Ahhhh, so this could be why the car is now LEAN!!!!!
I then went to the MCU and turned the dial from the all left position (I used to be chasing too rich as the result of the CHT) to something in the middle and now the car is running at what seems to be the correct mixture. No More Popping.
Changing the CHT if there are any rich/lean issues seems like a good place to start!
Next getting an O2 sensor from Mark Henry to vernier the mix-dial/idle-screw!
THANK YOU ALL TEENERS FOR THE SUPPORT! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/beerchug.gif)
Hi,
'74 2.0 with 20K miles.
Issues:
- high throttle, cannot get it to 800/900 - 1400/1600 is where it stays
- When de-accelerating the throttle is slow to get back to around 1400
Symptoms
- Idle adjustment screw does not get the throttle to a lower speed
- ECU adjustment has no effect
So far I have:
- Injectors are rebuilt with new gaskets, seem to be installed tight and correctly
- Rebuilt THrottle body
- Cannot detect any Throttle body leaks around the shaft
- New Plenum to Throttle Body gasket
- Valve adjustment
- All new hoses
- MPS holds 15in for 30 seconds +, induction is proper
- dwell is 47deg
Next Steps
Double Check timing
Remove plenum and the 4 connecting tubes
Replace gaskets and connector fabric/rubber things that are between the tubes and Plenum.
I have read and near memorized the Anders post on Rennlist, looking for any advise as to my chosen path to get this nailed.
Many thanks in advance.
CTC911CTC
Dave_Darling
post Mar 31 2019, 11:36 AM
914 Idiot
Ignition timing is a suspect. How freely does the advance move in your distributor?
Vacuum leaks are the other suspect. The posts through the plenum can cause cracks were they connect to the top and bottom of the plenum; those are hard to see. Other leaks can be inside the various bits, like the Decel Valve and the AAR. As well as leaks at hose connections or through old brittle cracked hoses. And let's not forget the PCV system...
--DD
Beebo Kanelle
post Mar 31 2019, 11:42 AM
QUOTE(Dave_Darling @ Mar 31 2019, 11:36 AM) *
--DD
I agree with the idea of a problem with the ignition timing - Of note, My idle was acting the same... until I fixed the advance in the distributor.
ctc911ctc   FIXED: Idle weirdness   Mar 31 2019, 11:29 AM
Dave_Darling   Ignition timing is a suspect. How freely does the...   Mar 31 2019, 11:36 AM
Beebo Kanelle   Ignition timing is a suspect. How freely does th...   Mar 31 2019, 11:42 AM
SirAndy   Vacuum leaks are the other suspect. :agree:   Mar 31 2019, 12:13 PM
mgphoto   De-accl valve installed the wrong way.   Mar 31 2019, 12:51 PM
ctc911ctc   De-accl valve installed the wrong way. Wow - d...   Mar 31 2019, 01:01 PM
ctc911ctc   De-accl valve installed the wrong way. Funny, l...   Mar 31 2019, 02:26 PM
ctc911ctc   READY-FIRE-AIM Of course this is a topic that has...   Mar 31 2019, 02:43 PM
ctc911ctc   I need this part but the web site only mentions 1....   Mar 31 2019, 01:30 PM
bdstone914   I need this part but the web site only mentions 1...   Apr 3 2019, 03:57 AM
dlee6204   I need this part but the web site only mentions 1...   Mar 31 2019, 02:40 PM
ctc911ctc   Thanks - will keep hunting for new gaskets. [quo...   Mar 31 2019, 02:44 PM
rhodyguy   Look closely at the stacked elbow.   Mar 31 2019, 02:44 PM
TheCabinetmaker   Classic symptom of an aar that is stuck open . Pin...   Apr 1 2019, 06:35 AM
ctc911ctc   ******UPDATE****** I found that when the engine i...   Apr 2 2019, 10:13 AM
Spoke   ******UPDATE****** I found that when the engine ...   Apr 2 2019, 11:19 AM
rjames   I'm going through something similar but haven...   Apr 2 2019, 02:21 PM
JawjaPorsche   Did you replace your intake manifold gaskets. Oil...   Apr 3 2019, 05:08 AM
ctc911ctc   I have purchased everything that is in the vacuum ...   Apr 3 2019, 07:15 AM
mgphoto   FYI there’s a guy on the samba that seems to kno...   Apr 3 2019, 10:25 AM
ctc911ctc   Makes sense - that will be the fall-back plan - I ...   Apr 3 2019, 10:34 AM
ctc911ctc   ************UPDATE*********** I have rebuilt the ...   May 12 2019, 11:01 AM
ctc911ctc   BUMPED: for all following this thread. *********...   May 17 2019, 08:20 AM
- Lo-Fi Version Time is now: 16th September 2026 - 05:36 PM
