-6 Remote Cooler Thermostat and Lines |
roblav1 |
Apr 7 2019, 06:31 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
-6 Build: Where are people installing the remote oil cooler thermostat? I want to weld in a bracket for it before paint. Kindof new to me since we never use remote oil thermostats in our formula racecars.
I was debating putting it on the right side - to run the oil out from the pump outlet in the case on the right side - to the thermostat, then split with one line going to the tank and the other to the cooler. It almost makes sense to run the feed line to the cooler on the right side and the return line from the cooler to the tank on the left side. But what confuses me is why does the oil thermostat have four ports instead of three? With three, one inlet port from the engine, one outlet port to the tank, and the other outlet port to the cooler. Where does the fourth port come into play? Thanks, Rob |
roblav1 |
Apr 7 2019, 09:58 PM
Thanks Mark.
Lo-Fi Version | Time is now: 9th June 2024 - 05:21 PM |
