LED Headlights: Turning on the fogs turns on the high beams, too!, New behavior, fogs worked normally until LED headlights installed. |
orthobiz |
Sep 17 2015, 05:26 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I love my brand new GE Nighthawks. There is no way I could go back to regular headlights. I had a set of sealed beam Hellas.
Last night I turned on the fog lights for the first time and the high beams came on. When I looked at the front of the car, all three were on: the regular lights, high beams AND the fog lights. Any fix for this? I would like to have the fog lights and the low beams on at the same time without the high beams. Edit: up until I installed the LED headlights, turning on the fog lights did NOT turn on the high beams. And turning on the high beams turned OFF the fog lights. In other words, normal behavior. Thanks, Paul |
Mikey914 |
Mar 31 2019, 12:52 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The load resistor needs to be on the low beam, to trigger the relay.
drem914 |
Apr 7 2019, 10:32 AM
Senior Member Group: Members Posts: 1,032 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Mikey914 |
Apr 7 2019, 10:19 PM
The load resistor needs to be on the low beam, to trigger the relay. Mark, I purchased the resistor from you, but am still waiting on a final wiring diagram so I know where and how to connect up. Scott said you might have that out soon? More than happy to take it back, Spoke’s solution is preferable. Mark |
drem914 |
Apr 8 2019, 09:05 AM
The load resistor needs to be on the low beam, to trigger the relay. Mark, I purchased the resistor from you, but am still waiting on a final wiring diagram so I know where and how to connect up. Scott said you might have that out soon? More than happy to take it back, Spoke’s solution is preferable. Mark Thank you, I'll bundle it up and send it back. It's stlll in the orignal bag you sent it in. |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:10 AM |
