> New 914 rear wheel bearing, No to very little grease from manufacture
Luke M
post Apr 10 2019, 12:05 PM
So, I just purchased a set of New FAG wheel bearing (made in Germany) so I can install a set of the later (74-89) 911 rear hubs on my 914 control arms.
I saw a few you tube videos about how the bearings for the Boxster where being shipped with little to no grease in them. I figured before I install them to check the grease. Well sure enough one side had little grease and the other side had very little to no grease on the bearings. I should've taken a few pics but didn't have my phone handy. I still have another new bearing to inspect so I'll take pics of that one. I'm sure it will be the same way. Now to go pick up some grease and repack them.
So if anyone of you out there plan on replacing your rear bearing I would inspect them.
Here's a handy video which shows how to do this.
https://www.youtube.com/watch?v=l9P1R2clGAU
Superhawk996
post Apr 11 2019, 04:47 AM
(IMG:style_emoticons/default/happy11.gif) That is the question isn't it.
The pictures that were posted in Brent's pages of the original grease pack was enough. They had grease on the cages but were not "packed".
The grease on the cages will distribute itself onto the balls and the race when it gets warm and has centrifugal force that will fling it radially outward bearing races.
As previously mentioned, the grease shouldn't be waxy if NOS bearings. As long as it has that viscous petroleum grease texture it will be OK.
Improper bearing installation technique is a lot more likely to lead to premature bearing failure than a light load of grease.
Again to avoid inflaming folks. No grease is not acceptable but it really does take a lot less that most of us think is necessary.
My advice is to trust the bearing manufacture's grease type and grease load. Any quality manufacturer (SKF, FAG, NSK, Timken, etc.) spends a lot of time to figure out what the right load is. The aftermarket bearings usually just copy what they find on OEM parts knowing that the OEM did the hard work and the development testing.
Luke M   New 914 rear wheel bearing   Apr 10 2019, 12:05 PM
914Sixer   Luke, Are those the ones I sent? They were old st...   Apr 10 2019, 12:09 PM
Luke M   Luke, Are those the ones I sent? They were old s...   Apr 10 2019, 02:47 PM
mepstein   I’ll check mine before I install. They need grea...   Apr 10 2019, 12:19 PM
Superhawk996   Don't want to rehash this whole topic. Brent ...   Apr 10 2019, 04:10 PM
914Sixer   I now wonder how much is ENOUGH.   Apr 10 2019, 08:46 PM
Superhawk996   :evilgrin: That is the question isn't it. T...   Apr 11 2019, 04:47 AM
mepstein   I wondered after seeing the boxster video if it wa...   Apr 11 2019, 05:29 AM
Luke M   The other thing that I noticed with the grease is ...   Apr 11 2019, 06:11 AM
bbrock   You have to scroll down to the second one I opened...   Apr 11 2019, 07:16 AM
Superhawk996   :stir: Bearings don't need much "lube...   Apr 11 2019, 08:17 AM
bbrock   :stromberg: still can happen though but it is ra...   Apr 11 2019, 09:20 AM
Superhawk996   :stir: The other thing to keep in mind for you g...   Apr 11 2019, 08:45 AM
Superhawk996   :Qarl: And to think - I started off never intend...   Apr 11 2019, 09:54 AM
bbrock   :Qarl: And to think - I started off never inten...   Apr 11 2019, 11:10 AM
Superhawk996   In the spirit of Laurel and Hardy. jzNbCWBJsSg   Apr 11 2019, 12:04 PM
KELTY360   In the spirit of Laurel and Hardy. jzNbCWBJsSg...   Apr 11 2019, 02:11 PM
Luke M   I got around to repacking the bearings today. I op...   Apr 11 2019, 05:30 PM
bbrock   I got around to repacking the bearings today. I o...   Apr 12 2019, 11:21 AM
worn   So, I just purchased a set of New FAG wheel beari...   Apr 11 2019, 07:26 PM
shane   This is probably a dumb question but it’s not my...   Apr 11 2019, 08:17 PM
davep   There is a good possibility that there is a bearin...   Apr 12 2019, 10:25 AM
Morph914   Out of curiosity I took apart my old one that appe...   Apr 12 2019, 01:15 PM
Superhawk996   :stir: :dance:   Apr 12 2019, 01:16 PM
Superhawk996   Any of you guys checking the bearing grease on you...   Apr 12 2019, 01:24 PM
bbrock   Any of you guys checking the bearing grease on yo...   Apr 12 2019, 01:38 PM
Superhawk996   :rotfl: :stir: The other thing that drastical...   Apr 12 2019, 02:34 PM
Superhawk996   Out of curiosity what type of Honda? Im curious w...   Apr 12 2019, 02:41 PM
bbrock   Out of curiosity what type of Honda? Im curious ...   Apr 12 2019, 02:52 PM
Superhawk996   Can’t tell for sure but it appears from YouTube ...   Apr 12 2019, 03:32 PM
bbrock   but I assume you are AWD given your location. ...   Apr 12 2019, 05:53 PM
Superhawk996   "I would assume the factory trained mechanics...   Apr 12 2019, 06:16 PM
Superhawk996   :evilgrin: Not done yet. Bearing pre-load, or ...   Apr 12 2019, 06:35 PM
mepstein   We hired two techs from Honda. I don’t think the...   Apr 12 2019, 07:34 PM
bbrock   Good info. Might be true about Honda techs but we...   Apr 12 2019, 10:03 PM
mepstein   Good info. Might be true about Honda techs but w...   Apr 13 2019, 05:40 AM
bbrock   Good info. Might be true about Honda techs but ...   Apr 13 2019, 08:48 AM
Superhawk996   @[url=http://www.914world.com/bbs2/index.php?showu...   Apr 13 2019, 07:15 AM
bbrock   Brent, I just want to be completely transparent t...   Apr 13 2019, 08:56 AM
mepstein   I used to use light oil on the bearings of my trac...   Apr 13 2019, 08:37 AM
- Lo-Fi Version Time is now: 4th March 2026 - 02:22 AM
