> Bolt Hole Empty?, By Design?
ctc911ctc
post Apr 13 2019, 05:02 PM
Hi,
As I was chasing a vacuum leak I found a seemingly important hole without a bolt? Is this be design?
The bottom hole is where the ground wires are attached - the hole above will assist in holding the Engine Together, could it hurt to add one there??????
bbrock
post Apr 13 2019, 07:29 PM
None of the 5 engines I've owned had a bolt there and it always bugged me. The PET doesn't show one there either. I just installed a CSP carb linkage bracket which uses that hole, and the one below for mounts. It doesn't bug me anymore. (IMG:style_emoticons/default/beer.gif)
wndsrfr
post Apr 14 2019, 07:21 AM
QUOTE(bbrock @ Apr 13 2019, 05:29 PM) *
Also helpful if you want to suspend the rear of the engine from a crossbar when dropping the trans ....
- Lo-Fi Version Time is now: 30th April 2026 - 04:28 AM
