> Oil Pressure Gauge, was working fine - but now it is pegged to the right side
rgolia
post Apr 15 2019, 02:41 PM
GeoJoe
Not sure what happened over the winter, but my oil pressure gauge is now pegged to the right. Worked fine all last driving season. Can a shot sender unit be the cause? Mine is really old. (IMG:style_emoticons/default/sad.gif)
914Sixer
post Apr 15 2019, 04:32 PM
Wire touching ground. Sending wire gets brittle from heat, breaks insulation and touches the metal brackets that hold it. Now you have the sender grounded out.
bdstone914
post Apr 15 2019, 05:36 PM
bdstone914
QUOTE(914Sixer @ Apr 15 2019, 03:32 PM) *
Wire touching ground. Sending wire gets brittle from heat, breaks insulation and touches the mental brackets that hold it. Now you have the sender grounded out.
bdstone914
post Apr 15 2019, 05:39 PM
bdstone914
QUOTE(bdstone914 @ Apr 15 2019, 04:36 PM) *
Either that or in the sender. Remove the se der wire from the sender. Connect an Ohm meter to the sender terminal G and to ground. If it shows continuity to ground the sender is bad. It should show a low resistance level and change with oil pressure change.
- Lo-Fi Version Time is now: 24th August 2026 - 03:26 PM
