> Tranz main shaft guide bolt, Looks like JB weld
malcolm2
post Apr 18 2019, 02:19 PM
Counting up all the things to order while i have it off for a new TO Bearing.
I found this. The stud pulled right out. Thoughts on repair?
ClayPerrine
post Apr 18 2019, 03:30 PM
Any of the listed inserts above will work.
But I would recommend that you measure the depth of the hole, and when you drill it out for the insert, wrap some tape around your drill bit as a stop. It is really easy to drill all the way through and end up with a gear oil leak.
- Lo-Fi Version Time is now: 31st October 2026 - 07:59 PM
