Door Cam Replacement, Drill The Rivet? |
Nogoodwithusernames |
Apr 19 2019, 09:45 AM
Member Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Hey guys, time to fix one of my door handles. The plastic cam broke. I'll probably pull the passenger side and clean the inner mechanism and replace the cam on that side too just to be safe.
I've got the driver side all cleaned and lubed up in the door, but cannot figure out how to get the plastic cam off to replace it. The handle doesn't open enough to let it slide out so do I need to drill the rivet and replace it with a shoulder bolt or something? PS I did try to read through some of the other threads about door handles but haven't found anything specifically regarding this yet. |
Mikey914 |
Apr 19 2019, 10:31 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I know I made mine with a notch so that you can extend the flap (pull the handle), and the notch will allow you to rotate the cam on and into place. Once installed it doesn't have this range of motion so it stays in place.
Does this help? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 11:38 PM |
