| naro914 |
Oct 26 2018, 08:33 AM
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
with all the work we're doing on Papa Smurf, one of big pieces of the development is tying the roll cage to the rear and front suspension points, plus doing tubing to strengthen other points around the car.
Would like to see how people run the tubes from the roll cage, through the fire wall or window, through the engine compartment area, into the rear trunk to the shock towers. We have things in the way there, but will move around if needed.... Thanks! |
| GregAmy |
Apr 21 2019, 02:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
For reference, I'm an SCCA scrutineer.
What caught my eye on this was that the rear braces do not appear to go up to within 6" of the top of the main hoop. The purpose of those rear bars is to ensure the integrity of the main hoop in case the world turns upside down on you. The braces you have there will support the bottom half of the main hoop, but that leaves the top half vulnerable to collapse. There are two ways to resolve this: - Run rear tubes that start within 6" of the top of the main hoop, and run the tubes through a polycarbonate rear window; see second part of GCR 9.4.c.2.e, quoted below. - If you don't want to run a poly rear windows, then follow first half of GCR 9.4.c.2.e that you quoted above, by adding plates to attach the cage to shoulder harness mounting points and adding a Petty Bar, from the top of the cage just to the right side of the driver's head (with sufficient clearance) down to the mounting plate for the right front leg. The first option is the more common and traditional method for "real" race cars, and allows you to continue that tube to strategic rear points on the chassis; that's the way my race car was built by Chris Foley. See attached. But maybe it's a dual-mission car and you don't want to run poly rear glass and/or cut into the car? Then you can use a Petty bar and the additional tab mounts as required. That Bar can also be sleeved to make it removable for the dual-mission, just ensure you make some kind of padded cap to go over the studs for safety in a road accident. GA QUOTE Alternatively, the rear window may be removed and a clear, lexan replacement installed. The rear cage braces may pass through this replacement window and through the engine cover or bodywork to allow connection to the frame or unibody. Such allowances shall be noted on the car’s specification line. Attached thumbnail(s) |
naro914 Show me your roll cage to suspension tower bracing Oct 26 2018, 08:33 AM
Mr. Olympic Blue 2 You Good luck with the refresh Bob! Oct 26 2018, 12:33 PM
Chi-town That style cross brace in the halo will collapse i... Oct 26 2018, 01:11 PM
naro914 Nice...I could use that rotisserie... Oct 26 2018, 01:27 PM
Brett W If I were doing the chassis, I would cut the curre... Oct 27 2018, 08:06 PM
Heater Guy
with all the work we're doing on Papa Smurf, ... Nov 3 2018, 03:13 PM
Krieger Check out my F-914 build in my signature. I have C... Nov 7 2018, 12:20 AM
Brett W That cage is of questionable legality for SCCA and... Nov 8 2018, 07:35 PM
ChrisFoley RE: Show me your roll cage to suspension tower bracing Nov 9 2018, 09:20 AM
mlindner Here's mine Bob. Best, Mark Nov 17 2018, 08:08 PM
mlindner One more shot of the passenger compartment before ... Nov 17 2018, 08:34 PM
campbellcj Here is a car I saw (I think) at a VARA event last... Nov 18 2018, 09:29 AM
Heater Guy
with all the work we're doing on Papa Smurf, ... Dec 4 2018, 07:41 PM
naro914
This cage is legal for SCCA. Just removed it fro... Dec 4 2018, 08:01 PM
Heater Guy
This cage is legal for SCCA. Just removed it fr... Dec 4 2018, 08:05 PM
naro914 ^^ah. thanks Dec 4 2018, 08:06 PM
ChrisFoley Without a full width main hoop crossbar that cage ... Dec 5 2018, 06:12 AM
naro914 That’s what my cage crossbar is like and it’s ... Dec 5 2018, 07:31 AM
ChrisFoley
That’s what my cage crossbar is like and it’s... Dec 5 2018, 07:35 AM
naro914
That’s what my cage crossbar is like and it’... Dec 5 2018, 08:40 AM
Heater Guy
[quote name='ChrisFoley' post='2671242' date='Dec... Dec 5 2018, 03:30 PM
Heater Guy
[quote name='naro914' post='2671256' date='Dec 5 ... Dec 5 2018, 03:51 PM
Chi-town Then the Tech inspector wasn't doing his job.
... Dec 5 2018, 09:53 AM
naro914
Then the Tech inspector wasn't doing his job.... Dec 5 2018, 02:33 PM
naro914 Recommended, not required.
We can’t put a knee b... Dec 5 2018, 03:59 PM
campbellcj
We can’t put a knee ... Dec 5 2018, 06:17 PM
brant agreed with Chris
knee bars go inside the dash an... Dec 6 2018, 11:03 AM
Brett W Yup, you need a better fabricator. Proper dash ba... Dec 9 2018, 11:14 AM
stownsen914 Definitely want a dash bar and a horizontal bar ac... Dec 9 2018, 11:00 PM
brant
Definitely want a horizontal bar across middle or... Dec 10 2018, 11:57 AM
naro914 OK then, can someone show pictures of their knee b... Dec 10 2018, 07:15 AM
Jetsetsurfshop My knee bar is almost touching the lower part of t... Dec 10 2018, 08:36 AM
ChrisFoley Forward hoops which penetrate the stock dash are g... Dec 10 2018, 09:22 AM
brant Ours: Dec 10 2018, 09:59 AM
Brett W Sounds like your seat is pushed too far forward or... Dec 10 2018, 11:31 AM
naro914 Nadine sits with the seat as far forward as she ca... Dec 10 2018, 11:43 AM
Jetsetsurfshop My knee bar, from Tangerine. Dec 10 2018, 01:33 PM
Brett W Too low, Nadine is now an amputee. That design wo... Dec 10 2018, 09:15 PM
GregAmy Good morning! Just catching this thread, wante... Dec 11 2018, 08:56 AM
Heater Guy
Good morning! Just catching this thread, want... Dec 11 2018, 11:40 AM
Chi-town @GregAmy - Thank you for the post and clarificati... Dec 11 2018, 09:14 AM
ThePaintedMan :agree: Greg nailed it. Which also makes me re-thi... Dec 11 2018, 10:53 AM
sixnotfour I cut the dash so the knee bar would be higher...... Dec 11 2018, 12:16 PM
GregAmy The orange historics car has a Foley cage from ... Dec 11 2018, 12:44 PM
naro914 Just met with my fabricator and he had already pla... Dec 12 2018, 11:29 AM
Heater Guy
Just met with my fabricator and he had already pl... Dec 12 2018, 12:28 PM
naro914
It must be realized that, for one reason or anoth... Dec 12 2018, 01:00 PM
Heater Guy
It must be realized that, for one reason or anot... Dec 12 2018, 01:14 PM
GregAmy Agree. Monthly SCCA Fast Tracks can sometimes driv... Dec 12 2018, 01:24 PM
Brett W
Plus double row "NASCAR" style door bar... Dec 13 2018, 07:30 AM
Chi-town
Apparently not, because he chose the second worse... Dec 13 2018, 09:02 AM
GregAmy There are a lot of different designs that people u... Dec 13 2018, 10:24 AM
Brett W I understand what he is talking about. In order f... Dec 13 2018, 09:20 AM
mlindner Here's mine, I'm six foot, never a problem... Dec 16 2018, 05:50 AM
Beechhousegarage Working on a T45 cage by Custom Cages UK,
Attachme... Apr 20 2019, 01:48 PM
Beechhousegarage another view Apr 20 2019, 01:50 PM
GregAmy Is that cage above being built to a specific sanct... Apr 20 2019, 07:34 PM
Beechhousegarage
Is that cage above being built to a specific sanc... Apr 21 2019, 10:56 AM
GregAmy Just a quick follow up that I forgot to mention.
... Apr 21 2019, 02:31 PM
Beechhousegarage Thanks Greg!
I may have been a little stubbor... Apr 21 2019, 05:39 PM
Beechhousegarage RE: Show me your roll cage to suspension tower bracing Apr 21 2019, 05:42 PM
GregAmy :beer2: Apr 21 2019, 07:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:52 AM |
