> tail shift, shift lever, replace worn tailshaft shifter lever
vincerobustello
post Apr 21 2019, 05:31 PM
I have a tremendous amount of wear in the cage on the tailshaft shift lever. does anyone have experience replacing this shaft? I found a replacement on Ebay but I am not sure what is involved in replacing the shaft. guidance and or illustration would be greatly appreciated.
VinceAttached Image
rhodyguy
post Apr 21 2019, 06:27 PM
Fairly easy as it lives at the back end of the trans. Looking up you'll see a small access cover. You need to drain the gear lube before you pull the cover and there will be some left where you have to work. Look at Fig 5.21 on page 86 of your Haynes. #14 has to be removed to start the rod piece into case. Do all of the disposables. The pin is the Tripple Rolled variety. Make sure you can remove the fill plug before you drain the lube.
- Lo-Fi Version Time is now: 5th March 2026 - 01:19 AM
