| BPic |
Apr 21 2019, 01:34 PM
Member ![]() ![]() Group: Members Posts: 343 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States
I have my harness out and I'm cleaning and replacing some wires. I'm also adding wires for AC and few other goodies. I want to have a center console with gauges and I'm stuck on this diagram. What do the numbers I'm pointing at reference? (IMG:style_emoticons/default/confused24.gif)
| narino |
Apr 21 2019, 06:30 PM
Member ![]() ![]() Group: Members Posts: 234 Joined: 14-August 07 From: Los Angeles, CA Member No.: 8,001 Region Association: None
Bpic - the numbers are wrong in that location. I had the same confusion when I received the diagram. When I get home I'll post my notes on what the correct numbers and labels should be.
*edit* Here are the errors I've caught so far on my diagram, which is for 72-73 years. Page 1/2 Light Switch: - Wire from pin 15 missing wire number 14 at end. - Wire from pin 58a wrong wire number at end (51). Should be 62. Page 2/2 Relay for Fresh Air: - Wire to pin 86 should be RD/WH, also missing wire number 14 at end. Heating Lever Light: - Brown wire number wrong (61). Should be 64. Hope that helps. |
| tmc914 |
Apr 21 2019, 07:52 PM
Member ![]() ![]() Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States
QUOTE Page 1/2 Light Switch: - Wire from pin 15 missing wire number 14 at end. - Wire from pin 58a wrong wire number at end (51). Should be 62. Page 2/2 Relay for Fresh Air: - Wire to pin 86 should be RD/WH, also missing wire number 14 at end. Heating Lever Light: - Brown wire number wrong (61). Should be 64. Hope that helps. Yes, this info helps a lot. Struggled with those errors early on but someone was able to help with a current diagram to bail me out. Hopefully others will see this in time so they don't struggle with errors on diagram. |
BPic Wiring Diagram Apr 21 2019, 01:34 PM
Rand Depends on the manual/chart, but I'd figure id... Apr 21 2019, 01:55 PM
GregAmy Are there number markings at the bottom of the cha... Apr 21 2019, 01:59 PM
BPic Thats exactly what I thought. However there is no ... Apr 21 2019, 02:16 PM
jcd914 They are continuation indicators, the circuit cont... Apr 21 2019, 05:42 PM
BPic
Bpic - the numbers are wrong in that location. I ... Apr 22 2019, 04:26 AM
GregAmy Here's a link to the factory diagrams:
http:/... Apr 21 2019, 07:52 PM
Tbrown4x4 I also found some errors in the Prospero's dia... Apr 22 2019, 04:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 18th March 2026 - 02:28 AM |
