| cashiersjm |
Apr 21 2019, 09:11 AM
Member ![]() Group: Members Posts: 41 Joined: 6-December 09 From: Hendersonville, North Carolina Member No.: 11,100 Region Association: South East States
Pulled the seats to work on the windshield & found this under the passenger seat.
I have carbs, no FI. Don't have a center console. Some wires so corroded they broke off. Others not connected, Some cut. Any direction to a schematic showing what all these are for would be greatly appreciated. ![]() |
| iankarr |
Apr 21 2019, 09:16 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,606 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
....And I believe the oil pressure sender wire connects at that block to the wire that goes to the gauge.
| Jonathan Livesay |
Apr 21 2019, 10:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 746 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None
....And I believe the oil pressure sender wire connects at that block to the wire that goes to the gauge. I'm pretty sure that wire comes through the firewall with everything else and just runs straight up the tunnel, along with the alternator warning light wire and the oil temp wire which ends at the plug just behind the shift lever if you don't have a temp gauge. |
cashiersjm What the heck is this for? Apr 21 2019, 09:11 AM
76-914 It's already been jumped. Nothing to do. The o... Apr 21 2019, 09:27 AM
Valy At this stage you only care about the big yellow w... Apr 21 2019, 09:37 AM
ClayPerrine
At this stage you only care about the big yellow ... Apr 21 2019, 08:50 PM
cashiersjm
At this stage you only care about the big yellow... Apr 22 2019, 04:51 AM
cashiersjm
....And I believe the oil pressure sender wire c... Apr 22 2019, 04:53 AM
Chi-town That contains the seat belt logic starter cut rela... Apr 22 2019, 09:16 AM
Dave_Darling There is no effect to unplugging that relay if the... Apr 22 2019, 11:10 AM
SirAndy Whatever you do, please don't cut any more wir... Apr 22 2019, 11:40 AM
JeffBowlsby There is no rear defroster relay at this location,... Apr 22 2019, 12:08 PM
cashiersjm I didn't cut any wires, just removed the seat ... Apr 22 2019, 05:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd September 2026 - 10:08 PM |
