tsvo |
Member ![]() ![]() Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest ![]() ![]() |
I have a 1973, 1.7 with FI still on it. The car is stalling at idle after the engine warms up. Any ideas what to adjust or look for? Things that may be contributing, but not sure. I think there is a vaccum leak. It smells like it is running rich. I recently replaced the fuel pump.
Any help is much appreciated. Thanks, Terry |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Vacuum leaks on Djet usually cause high idle. An exception is the MPS which fails to full rich if it doesn't hold a vacuum (whether via the hose or the diaphragm within). If you pull the vacuum hose off the MPS while it's running, what changes? |
tsvo |
(IMG:style_emoticons/default/agree.gif) Vacuum leaks on Djet usually cause high idle. An exception is the MPS which fails to full rich if it doesn't hold a vacuum (whether via the hose or the diaphragm within). If you pull the vacuum hose off the MPS while it's running, what changes? Thank you, I will be working on it this weekend. I appreciate your help. |
Lo-Fi Version | Time is now: 1st July 2025 - 01:01 PM |
