| drem914 |
Apr 24 2019, 03:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,067 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California
I am looking to add an amp for a footwell subwoofer. Where is the easiest and best place to pull power from? I really don't want to run a power lead back to the battery. If I have to do that I probably will scrap the whole idea.
TIA |
| drem914 |
Apr 24 2019, 04:37 PM
But I really don't want to drill anything or remove my recently install interior, back pad, seats, etc. You know the drill. Can the fuse panel just not handle the added load? Even for a small amp?
drem914 Power for amp? Apr 24 2019, 03:52 PM
jim_hoyland A separate line from the battery is recommended...... Apr 24 2019, 04:10 PM
bandjoey fuse panel has 1/2 always hot and 1/2 switchable h... Apr 24 2019, 05:10 PM
drem914
fuse panel has 1/2 always hot and 1/2 switchable ... Apr 25 2019, 10:43 AM
windforfun Don't forget the "Pi" filter. It at... Apr 24 2019, 05:20 PM
Dave_Darling If your amp and sub are low-powered, you can proba... Apr 24 2019, 09:55 PM
Steve I ran a thick wire through the center tunnel back ... Apr 25 2019, 06:28 AM
drem914
I ran a thick wire through the center tunnel back... Apr 25 2019, 10:41 AM
VegasVic
I ran a thick wire through the center tunnel back... Jun 1 2020, 06:05 PM
Steve
I ran a thick wire through the center tunnel bac... Jun 1 2020, 07:38 PM
VegasVic
Would you elaborate on your specific routing?
It... Jun 1 2020, 10:01 PM
VaccaRabite Don't go through the fuse panel. Run a wire t... Apr 25 2019, 11:33 AM
drem914
Don't go through the fuse panel. Run a wire ... Apr 25 2019, 03:07 PM
porschetub Only way is direct to battery,nothing in the fuse ... Apr 25 2019, 03:03 PM
windforfun Go with the largest power amp you can afford. Old... Apr 25 2019, 03:25 PM
Chris914n6 140w RMS@4ohm should be fine for a 8" sub in ... Apr 25 2019, 04:09 PM
drem914
140w RMS@4ohm should be fine for a 8" sub in... Apr 25 2019, 04:25 PM
Chris914n6
currently have this 8" Polk DVC https://www.... Apr 26 2019, 04:08 PM
windforfun
140w RMS@4ohm should be fine for a 8" sub in... Apr 25 2019, 05:49 PM
bbrock I have a couple pics of routing my amp wire on my ... Jun 1 2020, 06:56 PM
porschetub Did the same as Steve mentioned ,I used small posi... Jun 2 2020, 06:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 10:14 AM |
