| drem914 |
Apr 24 2019, 03:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,067 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California
I am looking to add an amp for a footwell subwoofer. Where is the easiest and best place to pull power from? I really don't want to run a power lead back to the battery. If I have to do that I probably will scrap the whole idea.
TIA |
| Steve |
Apr 25 2019, 06:28 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,022 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I ran a thick wire through the center tunnel back to the battery. I did not have to drill any holes or remove anything except for the carpet piece over the tunnel. I did put heat shrink over the power wire for extra insulation in the tunnel.
| drem914 |
Apr 25 2019, 10:41 AM
drem914 Power for amp? Apr 24 2019, 03:52 PM
jim_hoyland A separate line from the battery is recommended...... Apr 24 2019, 04:10 PM
drem914 But I really don't want to drill anything or r... Apr 24 2019, 04:37 PM
bandjoey fuse panel has 1/2 always hot and 1/2 switchable h... Apr 24 2019, 05:10 PM
drem914
fuse panel has 1/2 always hot and 1/2 switchable ... Apr 25 2019, 10:43 AM
windforfun Don't forget the "Pi" filter. It at... Apr 24 2019, 05:20 PM
Dave_Darling If your amp and sub are low-powered, you can proba... Apr 24 2019, 09:55 PM
VegasVic
I ran a thick wire through the center tunnel back... Jun 1 2020, 06:05 PM
Steve
I ran a thick wire through the center tunnel bac... Jun 1 2020, 07:38 PM
VegasVic
Would you elaborate on your specific routing?
It... Jun 1 2020, 10:01 PM
VaccaRabite Don't go through the fuse panel. Run a wire t... Apr 25 2019, 11:33 AM
drem914
Don't go through the fuse panel. Run a wire ... Apr 25 2019, 03:07 PM
porschetub Only way is direct to battery,nothing in the fuse ... Apr 25 2019, 03:03 PM
windforfun Go with the largest power amp you can afford. Old... Apr 25 2019, 03:25 PM
Chris914n6 140w RMS@4ohm should be fine for a 8" sub in ... Apr 25 2019, 04:09 PM
drem914
140w RMS@4ohm should be fine for a 8" sub in... Apr 25 2019, 04:25 PM
Chris914n6
currently have this 8" Polk DVC https://www.... Apr 26 2019, 04:08 PM
windforfun
140w RMS@4ohm should be fine for a 8" sub in... Apr 25 2019, 05:49 PM
bbrock I have a couple pics of routing my amp wire on my ... Jun 1 2020, 06:56 PM
porschetub Did the same as Steve mentioned ,I used small posi... Jun 2 2020, 06:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 10:13 AM |
