Sail panel, Bubbles |
tomh |
Apr 24 2019, 08:36 AM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
I re did the sail panels 2 years ago and now they are starting to bubble. I used the recommended adhesive and prepared the metal but it still happened.
Is there any fix without completely redoing the whole thing. Thanks |
DRPHIL914 |
Apr 26 2019, 08:16 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have had issues with this as well, and will be removing and re-installing mine again soon, probably this weekend before the local car show next weekend.
Last year when doing this the first time we used the spray on one , didn’t work out well so I removed it cleaned it up and redid it, the other side went much better with contact cement but still ended up with some spots releasing so This time I plan on using the 3M 99, and will try to make sure it’s applied to a clean surface and is allowed to cure properly, i may have rushed it last time but I also didn’t use the 3M 99 , will let you know how this works out- good luck on yours and have some help I found it impossible to do myself |
Lo-Fi Version | Time is now: 8th June 2024 - 10:01 AM |
