Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,737 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Or, in other words, where is a first time engine builder most likely to go wrong?
Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Incorrect alignment of cam and crank timing marks.
Breaking the eyelet off oil pickup when installing the bolt through the case. Not checking deck height and confirming compression ratio. Not lapping the cylinders to the heads. Not using correct sealant for case. Improper installation of oil cooler seals = leak Incorrect setting of the crank end play. Not surfacing pressure plate mounting surface the same amount as the clutch surface. Not that I have ever done any of those things. (IMG:style_emoticons/default/shades.gif) |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
Not surfacing pressure plate mounting surface the same amount as the clutch surface. Is grinding the ridges off the flywheel bolts a suitable work around for this? When I had my flywheel resurfaced decades ago, I asked them to surface the mounting hub to match but I don't think they did it. I decided to grind the bolts to be sure I have clearance but haven't run the engine yet. Is that going to bite me in the butt? Also, it's been a long time, but it seemed like installing the distributor gear was a little tricky. |
Mblizzard |
Not surfacing pressure plate mounting surface the same amount as the clutch surface. Is grinding the ridges off the flywheel bolts a suitable work around for this? When I had my flywheel resurfaced decades ago, I asked them to surface the mounting hub to match but I don't think they did it. I decided to grind the bolts to be sure I have clearance but haven't run the engine yet. Is that going to bite me in the butt? Also, it's been a long time, but it seemed like installing the distributor gear was a little tricky. I have seen that done but I think that is due to the removal of too much material from the surface and the bolts extend above the flywheel surface. If you fail to machine both surfaces clutch slippage will be a problem. If so much material was removed that you had to grind the bolts you might want to look at it again. I grade on a good bad scale. Anytime you have to modify bolts to fit stock parts it is likely bad! |
Lo-Fi Version | Time is now: 1st August 2025 - 12:02 PM |
