> What are the trickiest parts about rebuilding one of these engines? Thanks
Tdskip
post May 1 2019, 08:43 PM
Or, in other words, where is a first time engine builder most likely to go wrong?
Mblizzard
post May 2 2019, 06:59 AM
Incorrect alignment of cam and crank timing marks.
Breaking the eyelet off oil pickup when installing the bolt through the case.
Not checking deck height and confirming compression ratio.
Not lapping the cylinders to the heads.
Not using correct sealant for case.
Improper installation of oil cooler seals = leak
Incorrect setting of the crank end play.
Not surfacing pressure plate mounting surface the same amount as the clutch surface.
Not that I have ever done any of those things. (IMG:style_emoticons/default/shades.gif)
bbrock
post May 2 2019, 07:35 AM
QUOTE(Mblizzard @ May 2 2019, 06:59 AM) *
Is grinding the ridges off the flywheel bolts a suitable work around for this? When I had my flywheel resurfaced decades ago, I asked them to surface the mounting hub to match but I don't think they did it. I decided to grind the bolts to be sure I have clearance but haven't run the engine yet. Is that going to bite me in the butt?
Also, it's been a long time, but it seemed like installing the distributor gear was a little tricky.
Mblizzard
post May 2 2019, 08:00 AM
QUOTE(bbrock @ May 2 2019, 05:35 AM) *
I have seen that done but I think that is due to the removal of too much material from the surface and the bolts extend above the flywheel surface.
If you fail to machine both surfaces clutch slippage will be a problem. If so much material was removed that you had to grind the bolts you might want to look at it again. I grade on a good bad scale. Anytime you have to modify bolts to fit stock parts it is likely bad!
bbrock
post May 2 2019, 08:21 AM
QUOTE(Mblizzard @ May 2 2019, 08:00 AM) *
Whoops! Looks like a misread what you were saying. Yes, when my flywheel was surfaced, they took .027 off the friction surface and a matching amount off the outer ring where the pressure plate mounts. I mistakenly thought you were talking about the center hub where the flywheel bolts to the crank. That's what may not have been surfaced so I ground the ridges on the bolts just to make sure they don't hit the friction disc.
Disregard my question. Carry on. (IMG:style_emoticons/default/smile.gif)
jcd914
post May 2 2019, 10:12 AM
QUOTE(bbrock @ May 2 2019, 07:21 AM) *
This is not something that should be machined down when the flywheel is surfaced.
It is a structural part of the flywheel and should be left alone.
If enough material has been removed from the clutch surface of the flywheel the clutch disc can contact the flywheel bolts.
Really that means the flywheel is past its wear limit and should be replaced but I have seem many the have had the ridges on the flywheel bold ground down to add clearance. I have not seen a failure related to the specific modification.
There is a diagram with the machining specs for the 914/6 flywheel that seems to be the accepted standard for the 4cly flywheel as well. I don't think the bolts need to be ground if the flywheel is kept within the limits in the diagram.
I don't have a copy of the diagram handy or I would post it here.
Jim
Tdskip   What are the trickiest parts about rebuilding one of these engines? Thanks   May 1 2019, 08:43 PM
Mark Henry   Main bearing pinched on a dowel pin. Trying to che...   May 1 2019, 08:49 PM
Superhawk996   Thinking you know more about cooling tin, flaps,...   May 2 2019, 05:50 AM
Tdskip   That’s a good starting list-thanks   May 1 2019, 09:17 PM
Mblizzard   Incorrect alignment of cam and crank timing marks....   May 2 2019, 06:59 AM
bbrock   Not surfacing pressure plate mounting surface the...   May 2 2019, 07:35 AM
Mblizzard   Not surfacing pressure plate mounting surface th...   May 2 2019, 08:00 AM
bbrock   [quote name='bbrock' post='2710466' date='May 2 2...   May 2 2019, 08:21 AM
jcd914   I mistakenly thought you were talking about the ...   May 2 2019, 10:12 AM
Mblizzard   I mistakenly thought you were talking about the...   May 2 2019, 11:28 AM
bbrock   [quote name='bbrock' post='2710483' date='May 2 2...   May 2 2019, 11:38 AM
Tdskip   I won’t ask how you know Mike. Grin.   May 2 2019, 07:24 AM
Tdskip   I am assuming the do/don't on this is all writ...   May 2 2019, 08:19 AM
Tdskip   So really only an issue if the fly wheel has been ...   May 2 2019, 10:17 AM
rhodyguy   The run out on the fly wheel must be taken in to a...   May 2 2019, 10:26 AM
VaccaRabite   Echoing what Mark said. The dowel pin munching a m...   May 2 2019, 10:46 AM
worn   Or, in other words, where is a first time engine ...   May 2 2019, 11:22 AM
Superhawk996   is it just me misreading? I don't think dimen...   May 2 2019, 11:59 AM
rhodyguy   I was under the impression that 'C' is the...   May 2 2019, 12:01 PM
bbrock   I was under the impression that 'C' is th...   May 2 2019, 01:45 PM
sixnotfour   I was under the impression that 'C' is th...   May 3 2019, 09:32 AM
Superhawk996   @bbrock To Brent's point, as long as the 11m...   May 2 2019, 12:03 PM
sjhenry1075   I echo Mark's post about cooling tin; it's...   May 2 2019, 12:21 PM
mepstein   I echo Mark's post about cooling tin; it...   May 2 2019, 12:31 PM
Tbrown4x4   I'm also confused by that diagram. Always thou...   May 2 2019, 06:33 PM
bbrock   I'm also confused by that diagram. Always tho...   May 2 2019, 07:31 PM
Mark Henry   IIRC That diagram is for a 914/6 flywheel and isn...   May 2 2019, 07:18 PM
Superhawk996   IIRC That diagram is for a 914/6 flywheel and isn...   May 3 2019, 05:22 AM
Tbrown4x4   I agree. ^^^^ My machinist was all hung up on the...   May 3 2019, 04:55 AM
Tdskip   Great stuff. Short of splitting the case is there...   May 3 2019, 10:01 AM
Tdskip   Good morning. Came across this while doing more r...   May 9 2019, 07:33 AM
mepstein   Good morning. Came across this while doing more ...   May 9 2019, 10:36 AM
Bleyseng   Yes! Most cams are pretty worn after 75,000 mi...   May 9 2019, 08:23 AM
rhodyguy   You will have to tap the case for the threaded plu...   May 9 2019, 09:42 AM
Tdskip   Oh fine - steer me towards doing it right. Some he...   May 9 2019, 10:45 AM
sixnotfour   Oh fine - steer me towards doing it right. Some h...   May 9 2019, 12:21 PM
cuddy_k   Oh fine - steer me towards doing it right. Some h...   May 9 2019, 01:57 PM
Tdskip   Oh fine - steer me towards doing it right. Some ...   May 9 2019, 02:02 PM
Montreal914   I have really enjoyed Van Svenson's website fo...   May 9 2019, 01:53 PM
- Lo-Fi Version Time is now: 1st August 2025 - 12:05 PM
