915 Transmission Bott Conversion, Has anyone used one of these? |
Bates |
Apr 24 2019, 03:36 PM
Bates Group: Members Posts: 68 Joined: 27-December 13 From: Madison, Virginia Member No.: 16,800 Region Association: MidAtlantic Region |
I have my 3.0 SC motor ready, and my 915 transmission ready. I called WEVO to order a 915 sideshift conversion, and that part is no longer available.
Has anyone actually seen or installed one of the Bott Fahrzeugtechnik 915 conversions? Thanks Photos___Google_Photos.html ( 673.75k ) Number of downloads: 255 |
Dr Evil |
Apr 26 2019, 12:08 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I havent installed one yet, just did a Wevo. I like the Bott design better, and the rave reviews are compelling. As stated, you will need to flip the diff and some things may need machined. Flipping the diff is not just flipping, BTW. It needs to be measured and adjusted to get everything right.
mepstein |
Apr 26 2019, 12:50 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I havent installed one yet, just did a Wevo. I like the Bott design better, and the rave reviews are compelling. As stated, you will need to flip the diff and some things may need machined. Flipping the diff is not just flipping, BTW. It needs to be measured and adjusted to get everything right. I was told you need to set the lash but not the pinion depth if it’s a simple flip. |
Dr Evil |
May 6 2019, 01:37 PM
I havent installed one yet, just did a Wevo. I like the Bott design better, and the rave reviews are compelling. As stated, you will need to flip the diff and some things may need machined. Flipping the diff is not just flipping, BTW. It needs to be measured and adjusted to get everything right. I was told you need to set the lash but not the pinion depth if it’s a simple flip. Correct. If not disturbed (same shim going in) then the pinion is fine. Back lash setting is a pain in the ass. Just time consuming, but you can make tools if you have the measurements. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:09 PM |
