> Suspension, Improving ride
framos914
post May 10 2019, 12:18 AM
Just got my 75 2.0 back on the road after 24 years in the back of the garage. Last time I drove it back in 94 everything was pretty tight and smooth, now it seems to be all over the place. Was hoping to take it to WCR.
Any suggestions on where to start with the suspension?
Has 76 911S front koni struts, S calipers and sway bar. Rear 914-6 components.
Thanks
post May 10 2019, 11:33 AM
914-6 GT in waiting
New strut inserts, shocks and springs can make a huge difference. On all the 914's I've purchased in the last 10 years - about 20, they were all dead or dying. If the springs are worn out, you loose a lot of travel before the shocks bottom out. The wheel should only need a light touch for most driving so work your way through the checklist. And go to WCR no matter what since many of the great 914 minds will be there to help you sort the car.
When you did the brakes, I hope you did new soft lines. No matter how they look, they are dead after 35 years. The same goes with fuel lines. Be safe, not sorry.
framos914   Suspension   May 10 2019, 12:18 AM
sixnotfour   if the tires are 24 yrs old , that would be #1   May 10 2019, 01:07 AM
framos914   Tires are only a couple of years old   May 10 2019, 02:35 AM
falcor75   "All over the place" isnt much to go on....   May 10 2019, 02:41 AM
mepstein   :wttc: Yes, try to be more descriptive and check...   May 10 2019, 04:08 AM
Superhawk996   :agree: :wttc: Tires are prone to flat spotti...   May 10 2019, 06:31 AM
Andyrew   I would do the following: Oil change Bleed brake...   May 10 2019, 07:15 AM
jim_hoyland   :agree: 1.Tires 2. Alignment 3. Replace the rubbe...   May 10 2019, 07:20 AM
bdstone914   @framos914 :wttc: I am in riverside. If you br...   May 10 2019, 07:28 AM
framos914   Thanks everyone, this was my first post so i wasn...   May 10 2019, 11:03 AM
Racer   Bit of a bunch of things I imagine.. 1) Modern ri...   May 10 2019, 11:18 AM
mepstein   New strut inserts, shocks and springs can make a h...   May 10 2019, 11:33 AM
porschetub   My car rode really badly in the front,steering was...   May 10 2019, 02:06 PM
mbseto   That's a nice looking slant-nose.   May 10 2019, 02:36 PM
framos914   That's a nice looking slant-nose. Thanks, PO...   May 10 2019, 02:52 PM
Superhawk996   "when I hit any kind of bump it will jump and...   May 10 2019, 03:17 PM
framos914   "when I hit any kind of bump it will jump an...   May 10 2019, 04:23 PM
infraredcalvin   I’m with the guys above, check the aged maintena...   May 10 2019, 10:22 PM
- Lo-Fi Version Time is now: 18th March 2026 - 02:52 AM
