> Suspension, Improving ride
framos914
post May 10 2019, 12:18 AM
Just got my 75 2.0 back on the road after 24 years in the back of the garage. Last time I drove it back in 94 everything was pretty tight and smooth, now it seems to be all over the place. Was hoping to take it to WCR.
Any suggestions on where to start with the suspension?
Has 76 911S front koni struts, S calipers and sway bar. Rear 914-6 components.
Thanks
Superhawk996
post May 10 2019, 03:17 PM
"when I hit any kind of bump it will jump and feel a little out of control (gotta hold the wheel a little tighter)"
Still not sure about what you're describing.
What jumps? The steering wheel? (you mention having to hold tighter)
One thing to note in comparison to any modern car is that a 914 has a manual rack and pinion steering system. You will get A LOT more feedback in this car vs. any modern vehicle. Actual road feedback in the steering wheel is sorely lacking in almost all modern cars due to power assisted steering.
You also mention the steering seems to have too much play. This should not be the case the steering should be TIGHT. If you have play you have worn out components somewhere.
Prime Suspects that add play to steering:
Either the inner or the outer tie rod ends that go between the steering rack and the knuckle or both. The inner were rubber and can be degraded and/or dried out over time. The outer are a ball joint and could be worn.
The other thing that might be contributing is worn struts. 914's have some pretty bad bump steer characteristics. If a strut is worn and allows the suspension to easily travel to full jounce or full rebound, you'll get bump steer effects that can be felt in the steering wheel and will also make the vehicle feel "darty" or lacking straight line stability when it hits a bump in the road.
Per previous notes, you're going to have to work though this stuff one component at a time, inspect and replace as you go when you find worn components.
Part of the joy of a 45-50 year old car!
framos914   Suspension   May 10 2019, 12:18 AM
sixnotfour   if the tires are 24 yrs old , that would be #1   May 10 2019, 01:07 AM
framos914   Tires are only a couple of years old   May 10 2019, 02:35 AM
falcor75   "All over the place" isnt much to go on....   May 10 2019, 02:41 AM
mepstein   :wttc: Yes, try to be more descriptive and check...   May 10 2019, 04:08 AM
Superhawk996   :agree: :wttc: Tires are prone to flat spotti...   May 10 2019, 06:31 AM
Andyrew   I would do the following: Oil change Bleed brake...   May 10 2019, 07:15 AM
jim_hoyland   :agree: 1.Tires 2. Alignment 3. Replace the rubbe...   May 10 2019, 07:20 AM
bdstone914   @framos914 :wttc: I am in riverside. If you br...   May 10 2019, 07:28 AM
framos914   Thanks everyone, this was my first post so i wasn...   May 10 2019, 11:03 AM
Racer   Bit of a bunch of things I imagine.. 1) Modern ri...   May 10 2019, 11:18 AM
mepstein   New strut inserts, shocks and springs can make a h...   May 10 2019, 11:33 AM
porschetub   My car rode really badly in the front,steering was...   May 10 2019, 02:06 PM
mbseto   That's a nice looking slant-nose.   May 10 2019, 02:36 PM
framos914   That's a nice looking slant-nose. Thanks, PO...   May 10 2019, 02:52 PM
Superhawk996   "when I hit any kind of bump it will jump and...   May 10 2019, 03:17 PM
framos914   "when I hit any kind of bump it will jump an...   May 10 2019, 04:23 PM
infraredcalvin   I’m with the guys above, check the aged maintena...   May 10 2019, 10:22 PM
- Lo-Fi Version Time is now: 18th March 2026 - 01:07 AM
