| Krohn |
May 10 2019, 08:32 PM
Newbie ![]() Group: Members Posts: 9 Joined: 6-November 14 From: Santa Barbara, CA Member No.: 18,091 Region Association: Southern California |
Is there a magic trick or a special tool that's needed to remove the copper gasket from the head where the exhaust bolts?
I'm in the processing of cleaning (and more cleaning and more cleaning and more cleaning... ) from 50 years of oil leaks and in the process of partial disassembly for some push rod tube seal replacement, but after removing the head exchangers, I haven't found a reasonable way of removing the copper gaskets from the head. Any helpful experience or out there? |
| Superhawk996 |
May 11 2019, 07:52 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I have a small pick shaped tool with a slight bend in the tip. Just use it to hook underneath the copper gasket. It works every time.
I like Mark's idea too. (IMG:style_emoticons/default/beerchug.gif) Always up for making a new special tool from those I already have on hand! |
Krohn Exhaust to head gasket removal May 10 2019, 08:32 PM
Mark Henry Old flat screwdriver, heat the tip cherry red and ... May 10 2019, 09:09 PM
r_towle
Old flat screwdriver, heat the tip cherry red and... May 12 2019, 08:37 AM
Superhawk996
Old flat screwdriver, heat the tip cherry red an... May 12 2019, 08:45 AM
porschetub Be very careful removing these,if you damage the m... May 11 2019, 03:50 PM
Rand http://www.914world.com/bbs2/uploads_offsite/shop.... May 11 2019, 03:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 02:26 AM |
