> Exhaust to head gasket removal, Help removeing the copper exhaust gasket
Krohn
post May 10 2019, 08:32 PM
Is there a magic trick or a special tool that's needed to remove the copper gasket from the head where the exhaust bolts?
I'm in the processing of cleaning (and more cleaning and more cleaning and more cleaning... ) from 50 years of oil leaks and in the process of partial disassembly for some push rod tube seal replacement, but after removing the head exchangers, I haven't found a reasonable way of removing the copper gaskets from the head. Any helpful experience or out there?
porschetub
post May 11 2019, 03:50 PM
Be very careful removing these,if you damage the machined surface on the head you are basically screwed,they can be hard to get out with the motor installed.
I usually file the surfaces on heatexchangers and check for basic flatness with a straight edge,this method has cured exhaust leaks on 2 of my motors.
The studs require close inspection also as the end threads rust away,I use a self locking nuts I got from Pelican years ago,they are made for exhausts and from memory they were a early BMW part,so good I used them on my 2.2T six motor to really good result.
Good luck.
- Lo-Fi Version Time is now: 15th April 2026 - 02:22 AM
