> Hood Catch Problems, Pulling the handle won't release the catch.
defianty
post May 12 2019, 07:12 AM
I've gone though this about a hundred times now revisiting it every few days and I still can't get it to function.
When I disconnect the cable from the catch it moves freely when you pull the handle in the car. But when connected no amount of pulling will release the catch.
The catch is well lubed and moves freely when the springs are removed and can be activated by hand when the springs are installed - although it does require a strong thumb to move the lever.
Any ideas welcome before I do something I regret (IMG:style_emoticons/default/laugh.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-6621-1557666773.1.jpg)
post May 12 2019, 10:23 AM
Question: Does 914rubber product employee the same rigid plastic sheathing? I'm guessing it does as he did not suggest adding any clamps. Rigidity is key to cable actuated mechanisms be it heater, trunk and shifter cables. You can also wrap a SS safety wire around the mechanism and hide it behind the bumper. I made a loop at the end with a bit of hose to protect my finger when pulling. (IMG:style_emoticons/default/beerchug.gif)
defianty   Hood Catch Problems   May 12 2019, 07:12 AM
mepstein   Lube the pull handle in the car. Lube the cable in...   May 12 2019, 08:06 AM
defianty   Lube the pull handle in the car. Lube the cable i...   May 12 2019, 08:39 AM
r_towle   could be under too much tension once the hood is c...   May 12 2019, 08:29 AM
defianty   could be under too much tension once the hood is ...   May 12 2019, 08:41 AM
r_towle   could be under too much tension once the hood is...   May 12 2019, 08:45 AM
defianty   [quote name='defianty' post='2713249' date='May 1...   May 12 2019, 08:51 AM
r_towle   unless you are building a concourse queen, I would...   May 12 2019, 08:58 AM
mepstein   Quote from 914rubber a couple years ago - “I d...   May 12 2019, 09:00 AM
defianty   Quote from 914rubber a couple years ago - “I ...   May 12 2019, 09:22 AM
mepstein   Quote from 914rubber a couple years ago - “I...   May 12 2019, 09:24 AM
TJB/914   FYI I strongly suggest you install a safety pull ...   May 12 2019, 09:15 AM
North Coast Jim   After trying all the other help detailed herein I ...   May 12 2019, 09:31 AM
Steve   AFAIK there are two types. One with two springs a...   May 12 2019, 09:35 AM
76-914   Question: Does 914rubber product employee the same...   May 12 2019, 10:23 AM
defianty   After playing with it a bit more it wouldn't o...   May 12 2019, 10:23 AM
jim_hoyland   IIRC, the pull assembly has a screw in the shaft. ...   May 12 2019, 01:58 PM
mepstein   To lube the cable, Do not remove the housing. Loos...   May 12 2019, 02:35 PM
Mikey914   The tie down is important I see that others have m...   May 13 2019, 09:25 PM
defianty   The tie down is important I see that others have ...   May 14 2019, 01:33 AM
Mikey914   Good plan. No need to beat yourself. Sometimes thi...   May 14 2019, 02:20 PM
- Lo-Fi Version Time is now: 1st August 2025 - 11:05 AM
