> FIXED: Idle was HIGH, now too low, popping and missing VIDEO, Solution was CHT
ctc911ctc
post May 12 2019, 12:57 PM
I could not get the idle down below 1800, I took the advice from the excellent suggestions within 914world-garage and replaced EVERY gasket in the vacuum chain, including fixed a leaky plenum. """But mine looked so good - it can't be leaky! """ It was VERY leaky!
When I rebuilt the plenum (both sides of the support columns were leaky) and put it all back together, the resulting idle was way too low. I now have the reverse problem!
If I open up the ARR (remove hose) the idle is still low. If I take off the air cleaner and loosen the idle screw (all the way) still around 800-900. hhhhmmmmm.....
Throttle works, car will rev.
When driving the car it runs ok, however it does not have the power it used to have.
Engine is popping/missing, though the audio is not optimum, check out the video:
https://youtu.be/p5uM67DXJnk
Looking for next steps, what would you do next?????? (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
Background; '74 2.0 all STOCK with 20K miles, I have rebuilt:
throttle sensor PCB
Throttle control - does not leak, very smooth control, set spec on the electrics.
MPS - tested and perfect
PCV - seems to work
Injectors - just back from Hurst injectors - all on spec
Distributor - clean and spiffy, advance works
plugs - new
AAR - tested and works
Computer Control Unit - I have 2, have swapped them and they both perform the same.
Flow Down - on spec
Dwell set
Timing set
Many thanks in advance
CTC911CTC
ctc911ctc
post May 12 2019, 05:13 PM
***********fixing my own problem:
https://members.rennlist.com/pbanders/idle.htm
“ My idle doesn't change when I open the air bleed screw. What's wrong?
Very lean idle mixture: When the mixture is very lean, the air bypass has no effect on the idle speed. Go to a shop and have your idle CO measured and set to spec on a shop-quality analyzer. “
Next step, Mr. Anders suggestions! (IMG:style_emoticons/default/idea.gif)
- Lo-Fi Version Time is now: 8th October 2026 - 07:09 AM
