| Str1974 |
May 12 2019, 07:07 PM
Member ![]() ![]() Group: Members Posts: 90 Joined: 23-January 19 From: Dallas Member No.: 22,820 Region Association: Southwest Region |
I have a question regarding the back-up switch. I needed to replace it because the wiring connectors had broken off right where they plug into the two female connections on the switch (one underneath the back drivers side section of engine). I would have spliced the wire and connectors if I would have any length of wire left. All I have is bare wire and the two female connections. I've been trying to locate the right size bullet connectors that could be hooked up to bare wire, but no luck. The back up switch is easy to locate and purchase, but I cannot locate the male connectors. Any advise?
| rudedude |
May 12 2019, 07:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 555 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest
I think I've gotten them from stoddard
Str1974 914 613 541 02A back up switch connection May 12 2019, 07:07 PM
Str1974
I che... May 12 2019, 08:02 PM
Chris914n6 Common bullet connectors work. Might have stretche... May 12 2019, 08:32 PM
Bleyseng
Common bullet connectors work. Might have stretch... May 12 2019, 09:58 PM
Str1974
Common bullet connectors work. Might have stretch... May 13 2019, 10:22 AM
bdstone914 @Str1974
I got the correct ones from Bel Metric.... May 12 2019, 10:25 PM
Str1974
[b]@[url=http://www.914world.com/bbs2/index.php?s... May 13 2019, 10:24 AM
IronHillRestorations SAE bullet connectors will work May 13 2019, 07:25 AM
dr914@autoatlanta.com we always have plenty of the solder in bullets ava... May 13 2019, 08:21 AM
Bleyseng Yes, I picked up some of these so now I just have ... Jul 30 2019, 12:03 AM
mikesmith These worked well for me; generic 5mm R/C motor / ... Jul 31 2019, 07:06 PM
JeffBowlsby 4.5mm is the correct size for these terminals. Jul 31 2019, 09:32 PM
IronHillRestorations I use regular SAE bullet connectors, I just cut th... Jul 31 2019, 10:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:03 AM |
