Rebuilt calipers, Help needed |
Fatarse |
May 14 2019, 01:56 PM
Newbie Group: Members Posts: 12 Joined: 25-June 16 From: Scottsdale, AZ Member No.: 20,143 Region Association: None |
Right rear brake looks to have locked up after a recent caliper rebuild (less than 50 miles). I followed a pelican article and loosened the hex by going clockwise...wouldn’t twist counter. Brake pads look like they are glued to the rotor though...if anyone is in Phoenix area, there’s a six pack for anyone wanting to come to the garage and help me get the car on the road.
Attached thumbnail(s) |
Chi-town |
May 14 2019, 05:01 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Ok, there's an adjuster on both pistons in each caliper. Removed both caps (need to go through the hole in the trailing arm for the inside one) and unscrew the adjuster till you see the pad start to move back towards the caliper. Some times you have to push a little on the pad while turning the adjuster.
Once you get them backed off then you can set the correct gap. |
Fatarse |
May 14 2019, 05:23 PM
Does the caliper need to be removed in order to loosen the inner adjuster?
Lo-Fi Version | Time is now: 2nd June 2024 - 04:40 AM |
