> 911S strut assemblies, Inserts don't fit
framos914
post May 14 2019, 09:31 PM
Need help. My 75 2.0 has worn strut inserts, PO replaced front struts with what I believed were 1977 911S Koni struts part #911 341 079 16 stamped on it. Bought inserts Koni 86-1942. Problem is they bottom out before going in far enough to secure them with the round nut.
Could I have 72-74 911S struts? Did they have the same part number? And are those inserts (86-1638) just a little shorter to seat further down. The 1942s seem to be just about 12mm too long, body of the 1942 is 374mm long.
Tried getting info from a few places including Koni but no luck.
Thanks
914Sixer
post May 15 2019, 06:02 AM
I have a set of Koni 86-1942 and I have test fitted them in stock 73-on Boge Struts. You have to use the Boge nut but they fit. I have a set of 86-1647 which are made different but fit the same.
One on right is the 1942 and left one is 1647. BOTH are the same length. 14 1/2 inces or 37 cm.
framos914   911S strut assemblies   May 14 2019, 09:31 PM
mepstein   Off the top of my head, it sounds like you are try...   May 14 2019, 09:47 PM
framos914   Off the top of my head, it sounds like you are tr...   May 14 2019, 09:58 PM
infraredcalvin   it appears you have even earlier struts for 914-6/...   May 14 2019, 10:01 PM
Larmo63   Pictures might help us here, too.......?   May 14 2019, 10:04 PM
framos914   I'll try to get pictures tomorrow if the mecha...   May 14 2019, 10:13 PM
porschetub   I ordered replacements for what I knew were MY for...   May 14 2019, 11:47 PM
914Sixer   I have a set of Koni 86-1942 and I have test fitte...   May 15 2019, 06:02 AM
sixnotfour   real Koni Struts.. require a unique shock insert ....   May 15 2019, 08:56 AM
framos914   real Koni Struts.. require a unique shock insert ...   May 15 2019, 03:38 PM
mepstein   If it’s just one strut insert that won’t go do...   May 15 2019, 03:57 PM
sixnotfour   real Koni Strut housing /Spindles are special   May 15 2019, 09:38 PM
framos914   Passenger side strut   May 16 2019, 12:02 AM
framos914   RE: 911S strut assemblies   May 16 2019, 12:03 AM
framos914   Old insert   May 16 2019, 12:05 AM
framos914   New 861942 insert   May 16 2019, 12:11 AM
914Sixer   I have never seen that type of Koni insert. The n...   May 16 2019, 06:12 AM
infraredcalvin   Something has to account for that tab at the botto...   May 16 2019, 07:50 AM
framos914   The tab has two sides, I think on the original the...   May 16 2019, 10:23 AM
sixnotfour   your missing some pieces,,ie still in tube..   May 16 2019, 01:09 PM
framos914   your missing some pieces,,ie still in tube.. Tha...   May 16 2019, 02:49 PM
sixnotfour   your missing some pieces,,ie still in tube.. Th...   May 16 2019, 03:18 PM
framos914   Thanks again, that was it! Got those inserts...   May 16 2019, 09:57 PM
sixnotfour   Question: Some friends told me I ought to put some...   May 16 2019, 10:17 PM
sixnotfour   Question: What a rip, my 911 has original Koni str...   May 17 2019, 01:36 AM
- Lo-Fi Version Time is now: 2nd May 2026 - 07:22 AM
