| mmichalik |
May 15 2019, 03:14 PM
MikeM ![]() ![]() ![]() Group: Members Posts: 804 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California
Hi everyone,
We're about to pull the windshield moulding retaining clips out for the respray. I've taken out plenty of clips before but for some reason, these seem a little different. Is there anything special that should be done while removing them? Do we need to preserve any of the existing clip for future use? They appear to be a one and done but, I just wanted to make sure. Mike |
| iankarr |
May 15 2019, 03:33 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,609 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
If you're pulling the glass, the easiest way is to stick a putty knife between the trim and frame directly above each clip, then rap it with a hammer to break the plastic pin holding the clip in place. That way you can pull the rest of the clip from the trim off the car and not risk bending it. It's super soft.
If you're not pulling the glass, you'll need a trim clip tool to gently free the trim, as you'll want to keep those clips intact. There's no good way to re-install them without removing the glass. |
mmichalik Windshield Moulding Retaining Clips May 15 2019, 03:14 PM
Tom_T Hey Mike,
Off topic, but just a heads up that if ... May 15 2019, 04:23 PM
Mikey914 We do stock the trim removal tool if you need it a... May 16 2019, 12:11 AM
mmichalik Thanks for all the reply's, gentlemen.
We remo... May 16 2019, 08:02 AM
dr914@autoatlanta.com tap the pin through and always replace with new.
... May 16 2019, 09:32 AM
mmichalik Thanks George! That's what I figured but,... May 16 2019, 10:00 AM
cashiersjm I've been working on my windshield and receive... May 16 2019, 10:40 AM
Mikey914 Thanks we did make some improvements to hopefully ... May 17 2019, 11:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2026 - 03:53 AM |
