First stop on the diagnosis train: asking the forum., 1911 sounds like marbles in a tin can. |
Optimusglen |
May 15 2019, 11:56 PM
Senior Member Group: Members Posts: 912 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
A recent occurrence, I'm getting a pretty loud rattle that sounds like marbles swirling around the bottom of a tin can. Everything else seems fine, power etc. Hear it while in neutral and idling and also while driving in gear. It's drown out by wind noise the faster you go.
Engine is a 1.7 punched up to 1911 on dual Weber 40's. Heat exchangers stripped to bare headers, new muffler. Oil pressure and cylinder head temp both normal. |
ejm |
May 16 2019, 07:40 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Could be the alternator bearings. Pull the belt and see if the noise goes away.
Lo-Fi Version | Time is now: 6th June 2024 - 03:31 AM |
