| ctc911ctc |
May 12 2019, 12:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,385 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
I could not get the idle down below 1800, I took the advice from the excellent suggestions within 914world-garage and replaced EVERY gasket in the vacuum chain, including fixed a leaky plenum. """But mine looked so good - it can't be leaky! """ It was VERY leaky!
When I rebuilt the plenum (both sides of the support columns were leaky) and put it all back together, the resulting idle was way too low. I now have the reverse problem! If I open up the ARR (remove hose) the idle is still low. If I take off the air cleaner and loosen the idle screw (all the way) still around 800-900. hhhhmmmmm..... Throttle works, car will rev. When driving the car it runs ok, however it does not have the power it used to have. Engine is popping/missing, though the audio is not optimum, check out the video: https://youtu.be/p5uM67DXJnk Looking for next steps, what would you do next?????? (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) Background; '74 2.0 all STOCK with 20K miles, I have rebuilt: throttle sensor PCB Throttle control - does not leak, very smooth control, set spec on the electrics. MPS - tested and perfect PCV - seems to work Injectors - just back from Hurst injectors - all on spec Distributor - clean and spiffy, advance works plugs - new AAR - tested and works Computer Control Unit - I have 2, have swapped them and they both perform the same. Flow Down - on spec Dwell set Timing set Many thanks in advance CTC911CTC |
| rjames |
May 17 2019, 02:51 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,477 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Did the new CHT sensor not work correctly? Or did you just put the old one back in to test it?
ctc911ctc FIXED: Idle was HIGH, now too low, popping and missing VIDEO May 12 2019, 12:57 PM
ctc911ctc ***********fixing my own problem:
https://members... May 12 2019, 05:13 PM
r_towle is the CHT plugged in?
you are still getting air i... May 12 2019, 06:01 PM
76-914 Dwell and timing done since the low idle raised it... May 12 2019, 06:19 PM
ctc911ctc **************PROBLEM SOLVED************
Picked u... May 16 2019, 08:42 AM
Superhawk996 Out of curiosity - what is the part number on the ... May 16 2019, 06:37 PM
JawjaPorsche
Out of curiosity - what is the part number on the... May 17 2019, 03:16 AM
ctc911ctc
Out of curiosity - what is the part number on the... May 17 2019, 08:07 AM
ctc911ctc I took the old one out after I took the plenum out... May 18 2019, 07:34 PM
914_teener So the CHT is just a thermister.
It is easy to ... May 18 2019, 07:57 PM
ctc911ctc In this thread there is a picture of me testing th... May 19 2019, 06:51 PM
rhodyguy Cutting a slot for the wire in the side of a deep ... May 19 2019, 03:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th October 2026 - 07:09 AM |
