| jdamiano |
May 18 2019, 06:57 PM
Member ![]() ![]() Group: Members Posts: 336 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
Working on my friends Creamsicle today because it had intermittent cranking and cranking with no start issues. We traced the no crank issues to the ignition switch and finished breaking the no start issues. It just cranks and sounds like it’s gonna go for a second then nothing. Fuel pressure is 28psi while cranking. Fires right up with a squirt of starting fluid and runs off it for a couple seconds then dies. Seems the injectors aren’t firing. Is power for the FI through the ignition switch? Since it’s wonky with cranking I’m thinking maybe it’s bad for other functions.
| BeatNavy |
May 18 2019, 07:12 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
The trigger point connectors at the back of the dizzy ground the injectors in pairs causing them to "fire." If that connector is disconnected you won't get any fuel, so it won't even attempt to start. I agree, that is the first thing I would check.
jdamiano Calling FI Experts May 18 2019, 06:57 PM
76-914
Working on my friends Creamsicle today because it... May 18 2019, 07:01 PM
JeffBowlsby
The trigger point connectors at the back of the d... May 19 2019, 07:59 AM
cary Plus check the harness grounds. That was my issue ... May 18 2019, 11:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 03:41 AM |
