| Bibble |
May 18 2019, 10:16 PM
Newbie ![]() Group: Members Posts: 32 Joined: 19-December 15 From: United Kingdom Member No.: 19,472 Region Association: None |
Hello all,
I am looking to get my ECU refurbished - the car was running very rich when it came off the road around 15 months ago. I have started to tidy up the pipes, check the mps, connectors etc but as I’m committed to retaining the original set up, I would like to have the ECU in top order, for now and the future. Took mine out yesterday and noted the serial number is very close to the rennlist table detailing the ECUs fitted but mine is slightly different - Bosch - 0280000032 as against 0280000037. The VW serial number is 022906021C which again is close with the same numbers just a different letter either A or U but seem to be either A or Bs or U ... but not a C ... My question is, is this an issue? Or just a slightly different number but essentially the correct ECU for the car? My car was first registered in the UK in October 1971. I only ever seem to see the Bosch versions ending in 037 on eBay etc. Also, any recommendations on a good company either in Europe to avoid customs duty or the USA to recondition my unit assuming it’s the correct one. Many thanks for any advice Jonathan |
| Bleyseng |
May 19 2019, 08:04 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I have one for a 70-71 914 if you want it.
I understand it has the overrun circuit like the 75-76 052 ECU's have. What is that? Well, when you are driving along and you lift your foot off the gas petal you coast as the ECU shuts off the injectors until 2000 rpms when it turns them back on. My 77 VW bus with Ljet does the same thing so its to stop a over rich running when decelerating. |
Bibble Correct ECU for 1.7 registered October 1971 May 18 2019, 10:16 PM
914_7T3 This has been the best resource for part # informa... May 18 2019, 10:22 PM
Bleyseng Early ECU’s don’t have a idle mix adjustment k... May 19 2019, 12:07 AM
porschetub What is giving you the indication the ECU is fault... May 19 2019, 12:25 AM
mepstein Like others said, the ecu is usually the last thin... May 19 2019, 05:22 AM
JeffBowlsby Checking the PNs, you clearly have the wrong ECU f... May 19 2019, 07:51 AM
porschetub
Checking the PNs, you clearly have the wrong ECU ... May 19 2019, 05:00 PM
Bibble
Checking the PNs, you clearly have the wrong ECU... May 19 2019, 10:30 PM
Bleyseng
[quote name='porschetub' post='2715181' date='May... May 20 2019, 08:43 AM
yellowporky http://www.914world.com/bbs2/index.php?sho...=3135... May 19 2019, 12:12 PM
porschetub I think you need the early one for your car ,just ... May 19 2019, 11:22 PM
dr914@autoatlanta.com are you sure that yours is bad? Few fail and ther... May 20 2019, 09:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 08:35 PM |
