Where does this white wire go? |
John90290 |
May 18 2019, 12:13 PM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
1975 1.8 FI. Got engine back in and most things commented bit don’t know what this white wire connects to ?
Attached thumbnail(s) |
Dave_Darling |
May 19 2019, 11:50 AM
It goes under the car. On cars that have an oil temperature gauge, there should be a wire across the front of the motor on the underside of the engine tin, terminating in a connector under that area. The wire pictured there goes down through a hole in the engine shelf--or possibly that hole in the engine tin that is covered by the black plug in your pic?--and connects to it.
--DD |
John90290 |
May 19 2019, 11:54 AM
It goes under the car. On cars that have an oil temperature gauge, there should be a wire across the front of the motor on the underside of the engine tin, terminating in a connector under that area. The wire pictured there goes down through a hole in the engine shelf--or possibly that hole in the engine tin that is covered by the black plug in your pic?--and connects to it. --DD awesomeness!!! You guys are great! Now I have to get the fuel pump working. That’s another post (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 03:38 PM |
