Engine Re-Seal Guidance, What to replace and where to buy |
tvdinnerbythepool |
May 23 2019, 03:39 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Hey all,
Whilst the engine is out and I repair the hell hole, I’d like to re-seal the engine. Definitely leaking and making a mess in the garage as well as the cloud of smoke as it warms up and the HEs cook off the fresh drips. I am new to the type IV and was wondering if you guys could give me a list of... -what seals there are to be replaced? -Order in which to replace? -recommendations on kits or vendors for needed seals? Thanks for the guidance! It’s greatly appreciated (IMG:style_emoticons/default/welder.gif) |
rhodyguy |
May 24 2019, 01:45 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Figure out the deal with the bolts, figure out the stacking requirements for the shims, buy a dial indicator and figure out how to use it, buy a FW lock. Might as well send the flywheel out for machining (hopefully in spec when finish) just replace everything...why not buy a set of appropriate 96mm Pistons/cyl/rings and put those on while the engine is out? Oh, send the heads out for a refresh. remove and tap the rear galley plugs. One has to stop adding on. Overwhelming for a newer owner or one with limited skills. Don't forget to refurb the shifter itself. Those pesky detention plates. Hopefully the plate has not worn into the lever.
However, I would do the lube for the gear box while removed. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:47 PM |
