| orthobiz |
May 27 2019, 06:09 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,762 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
For two or three years now, two of my cars leak gasoline when taken out of winter hibernation and fired up. Run it long enough to realize it's leaking. Let stand overnight. Then, absolutely bone dry (couldn't resist that one).
I am told that this is not uncommon but did not find thread specifically mentioning this springtime phenomenon. Seems like "once a leak, always a leak." That has not been my experience. Apparently exposure to gasoline causes the internal seals to swell and seal up? So far, the cars have been fine for the rest of our pitifully short Michigan driving season. I am pretty sure it is from the injector itself, can't imagine bad hoses would seal themselves. Is it possible NO ONE makes injectors for our cars???? 350 per new injector is steep and I wonder if shelf time is bad for the seals or whatever inside the injectors NOS. Like hard old rubber. Extinguisher? Yes, on board, all the time, every car. Am I driving a time bomb or have others experienced this? Paul |
| mepstein |
May 27 2019, 07:33 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Paul - It would be good to know exactly what was leaking. Was it the injector, the hose or either of the seals that seal the injector to the engine. The 2 injector seals are about a dollar each and the hoses are pretty inexpensive, compared to a new injector. Plus, all these rubber parts are easily replaced in 10-15 minutes.
I had been talking to Dave about a engine stumble problem on his 3.2 conversion. He did a lot of diagnosis to try to fix and then discovered it was just a kink in the fuel line. Sometimes the solution is easy. |
| orthobiz |
May 27 2019, 07:49 AM
As best I can tell, it's the injector, not the engine seals or the hose. Besides, would the other sources "seal up" after sitting overnight? Has anyone else had injector leaks "cured" by running the engine briefly and coming back to a completely dry engine the next day?
On my 1.8 the CSV leaked this year, a different injector leaked last year. Paul Paul - It would be good to know exactly what was leaking. Was it the injector, the hose or either of the seals that seal the injector to the engine. The 2 injector seals are about a dollar each and the hoses are pretty inexpensive, compared to a new injector. Plus, all these rubber parts are easily replaced in 10-15 minutes. I had been talking to Dave about a engine stumble problem on his 3.2 conversion. He did a lot of diagnosis to try to fix and then discovered it was just a kink in the fuel line. Sometimes the solution is easy. |
orthobiz Fuel Injectors: I "springed" a leak...Been a long winter. May 27 2019, 06:09 AM
rjames Engine fires aren’t worth taking a chance on. If... May 27 2019, 10:15 AM
Engine fires aren’t worth taking a chance on. I... May 27 2019, 10:35 AM
dabird I had one injector leak last fall. Started it for ... May 27 2019, 10:24 AM
JamesM I have been having the same issue on one of my 914... May 27 2019, 12:05 PM
dabird I would be really happy if mine stopped leaking. I... May 27 2019, 12:22 PM
isdyl I’ve had leaky injectors on a number of d-jet Me... May 27 2019, 01:06 PM
I’ve had leaky injectors on a number of d-jet M... May 27 2019, 01:56 PM
dabird Update on my own car experiencing this quirk. I ju... May 27 2019, 02:43 PM
orthobiz Thanks for the input. Glad to see I'm not alon... May 27 2019, 03:12 PM
rjames the small crimped on pre-installed hose connected ... May 27 2019, 03:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:54 PM |
