| orthobiz |
May 27 2019, 06:09 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,762 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
For two or three years now, two of my cars leak gasoline when taken out of winter hibernation and fired up. Run it long enough to realize it's leaking. Let stand overnight. Then, absolutely bone dry (couldn't resist that one).
I am told that this is not uncommon but did not find thread specifically mentioning this springtime phenomenon. Seems like "once a leak, always a leak." That has not been my experience. Apparently exposure to gasoline causes the internal seals to swell and seal up? So far, the cars have been fine for the rest of our pitifully short Michigan driving season. I am pretty sure it is from the injector itself, can't imagine bad hoses would seal themselves. Is it possible NO ONE makes injectors for our cars???? 350 per new injector is steep and I wonder if shelf time is bad for the seals or whatever inside the injectors NOS. Like hard old rubber. Extinguisher? Yes, on board, all the time, every car. Am I driving a time bomb or have others experienced this? Paul |
| JamesM |
May 27 2019, 12:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,187 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I have been having the same issue on one of my 914s where one of the injector bodys (and sometimes the pump body) will leak a little when first pressurized in the spring but then goes away and is fine the rest of the season. Always makes me super nervous when i see it, but that is why i always bring my halon bottle with me.
As for replacements, I have not personally tried these yet but I noticed them when hunting for some injectors for a new Megasquirt project I am working on.. https://www.fiveomotorsport.com/porsche-fiv...reman-55213104/ https://www.fiveomotorsport.com/10399-36lbs-hoses-clamps/ Not sure what the difference is on those two parts, but they are listed as NEW replacements for 2.0 D-jet cars. they appear to have l-jet rather than d-jet connectors however I believe d-jet connectors will still fit, though just upgrading your harness connectors to l-jet style would probably be an improvement. I have a set of what appears to be these injectors that came with a rebuilt 2.0 motor i picked up. I havent fired it up yet, debating if I give them a shot or replace them with an OEM set. Ive considered sending them out along side an OEM set to get them flow benched and compared. If anyone has that data I would love to see it. |
orthobiz Fuel Injectors: I "springed" a leak...Been a long winter. May 27 2019, 06:09 AM
mepstein Paul - It would be good to know exactly what was l... May 27 2019, 07:33 AM
orthobiz As best I can tell, it's the injector, not the... May 27 2019, 07:49 AM
rjames Engine fires aren’t worth taking a chance on. If... May 27 2019, 10:15 AM
Engine fires aren’t worth taking a chance on. I... May 27 2019, 10:35 AM
dabird I had one injector leak last fall. Started it for ... May 27 2019, 10:24 AM
dabird I would be really happy if mine stopped leaking. I... May 27 2019, 12:22 PM
isdyl I’ve had leaky injectors on a number of d-jet Me... May 27 2019, 01:06 PM
I’ve had leaky injectors on a number of d-jet M... May 27 2019, 01:56 PM
dabird Update on my own car experiencing this quirk. I ju... May 27 2019, 02:43 PM
orthobiz Thanks for the input. Glad to see I'm not alon... May 27 2019, 03:12 PM
rjames the small crimped on pre-installed hose connected ... May 27 2019, 03:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:31 PM |
