| malcolm2 |
May 28 2019, 04:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
I jacked up the car, lowered the hand brake and attempted to spin the driver's side wheel. NO GO. Removed the wheel and pushed the hand brake lever on the caliper away from the caliper. TA DA Rotor turns.
repeated hand brake lifts and the lever returned properly. So the Clymer nor the Haynes manuals say anything at all about lubrication. I did notice that I don't have the rubber boot on the caliper end of the cable, so dirt in the tube could be a thing. To me the feel for release was the lever. Actual question is: Should I lubricate the shaft, spring, lever.....? maybe some lightweight oil or Sili-Kroil? |
davep I would be inclined to remove the cables, spray so... May 28 2019, 05:27 PM
malcolm2 I was thinking the same thing. I was able to blow... May 28 2019, 08:03 PM
malcolm2 Double post May 28 2019, 08:03 PM
Specracer Also you should have a return spring inside the ca... May 29 2019, 04:42 AM
malcolm2 I would like to get some of the rubber bellows tha... May 29 2019, 04:26 PM
malcolm2 It has been a while.... but I LUBED the hell out o... Aug 25 2019, 05:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th April 2026 - 12:42 AM |
