WTB a Dead Koni Red For Autopsy, The crappier the better! |
Tbrown4x4 |
Jun 4 2019, 06:32 PM
Senior Member Group: Members Posts: 705 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Hi All.
I would like to buy an old Koni red rear shock for scientific purposes. It will be cut up and examined. Since I am a cheap SOB, I can't bring myself to pay someone $300 to rebuild an old shock, and I'd rather not pay $200+ for a new one, just for a bad seal. Koni NA tells me to talk to their certified rebuilders, and the rebuilders tell me they are under contract from Koni not to sell parts. My findings could benefit the community. I already have the tool to remove the wiper seal, and a proper pin spanner for the shock cap, but it refuses to budge. I need to know if it's pressed in, welded somehow, or just TIGHT before I force it and do damage. (I do have a 3 ft pipe wrench.) So..... dented, bent, broken, free, etc. What do you have. I promise to post pictures! Todd |
AnthonyM |
Jun 5 2019, 07:53 PM
Newbie Group: Members Posts: 38 Joined: 8-December 12 From: Hudson, OH Member No.: 15,243 Region Association: North East States |
I used to work for Koni N/A in Motorsports and have had several of the older shocks apart. One cause is the breakdown of a nylon spacer that deteriorates in the oil and then stops up the bleed holes and prevents oil flow thru the bleeds and valving. Other issues could be caused from bottoming out the shock and damaging the internal components or simply a failed internal part. If you have a spanner that fits the pin id and the spread, you should be able to loosen the gland nut and take the shock apart. This process will work as long as your talking about an OE twin tube replacement shock. Mono tube shocks are assembled differently.
Lo-Fi Version | Time is now: 12th June 2024 - 12:40 AM |
