| porschetub |
Jun 11 2019, 07:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,171 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Got the car out of storage for a startup and short drive yesterday,noticed the engagement point is high on the pedal (again),obviously isn't happy there,and not fun to drive this way.
Sometime back I shimmed the ball pivot as it was clear the throw out lever was contacting the gearbox casing...not by much but after measurement it appeared my flywheel had been resurfaced @ some stage but still in spec. Cable was new when I did the 6 conversion 708kms ago,and I cant find any movement in the tunnel tube,clutch is new and all wear parts replaced on the throw-out lever and bearing,have new 914rubber cable roller also. Really got me buggered this one ,why do I need to adjust it so often.....bad cable who knows. TIA |
| porschetub |
Jun 11 2019, 10:12 PM
Thanks for the replies folks ;
Spoke was the cable new? I don't remember the brand I bought off Pelican but remember most use them,maybe I have a bad one ?. Perry,pedal assembly fully rebuilt and all good ,new bronze bushes and repaired the the flogged out clutch arm and replaced the clevis. Done the test on the tube and only slight deflection near the front in the tunnel,I do think the pedal is somewhat heavy however,is that telling me anything ????. Again thanks. |
porschetub Clutch adjustment issues ! Jun 11 2019, 07:28 PM
Spoke I went through about a month of clutch adjustments... Jun 11 2019, 07:35 PM
IronHillRestorations I've seen problems caused by a faulty roll pin... Jun 11 2019, 07:35 PM
bdstone914 @ porschetub
' date='Jun 11 2019, 09:12 P... Jun 13 2019, 07:42 AM
rjames Is the nut loosening itself on the transmission en... Jun 12 2019, 12:27 AM
porschetub
Is the nut loosening itself on the transmission e... Jun 12 2019, 01:59 PM
rjames Double post Jun 12 2019, 12:27 AM
Rand Every lurker is wondering if the firewall crack is... Jun 12 2019, 02:35 PM
porschetub
Every lurker is wondering if the firewall crack i... Jun 12 2019, 03:07 PM
porschetub Thanks Bruce ,guess this should be rechecked as it... Jun 15 2019, 03:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th September 2026 - 05:02 PM |
