| Tjmrfe |
Jun 12 2019, 09:23 AM
NON IMPEDING RATIONE COGITATIONIS ![]() ![]() Group: Members Posts: 132 Joined: 10-April 15 From: Cornwall on Hudson, New York Member No.: 18,612 Region Association: North East States |
Hey Guys, couldn’t take the leaking oil anymore....so, in a bold move, I decided to pull the motor! I’ve got everything sorted, all my ground straps and wiring is off...went down the check list, got my Tangerine plate and my dolly...now all I need is a guide, or two?...I’m more than willing to throw a BBQ together and refreshments I’m thinking the second weekend in July? 13/14....either day works...should not take too long, just four bolts right? Lol...I’m in Cornwall NY near West Point...PM me if you’ve got a free few hours that weekend, this way I can get it out and see how bad the oil leaks are!...
| ndfrigi |
Jun 12 2019, 09:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
you’re almost there to drop your engine. For sure you can do it by yourself.
Is your current lifter can drop your engine all the way down a furniture dolly and the highest to raise your car (rear valance) can get around 29”? so you can pull the engine. (engine and dolly height is around 28”) Or use 2 floor jack to raise and lower your rear car during the engine removal. 1. All cables remove like clutch , accelerator, speedo 2. All wirings to top engine (F.I. or carb) 3. Tranny ground strap 4. Remove exhaust (it is fine also not removing it but easier and more space to work underneath) 5. Raise your rear a little bit enough for your to work underneath. 6. Loosen the tranny and engine mount bolts just enough for you to totally remove them later 7. Put your furniture dolly under the rear (vertical way of ur dolly) 8. Drop your rear slowly one side at a time (if using 2 floor jack) until the engine touches your dolly (engine mount drop to one side of the padding of your dolly and rear end of dolly pad along tranny and you may need a small wood block for dolly to tranny) Note: check also your rotor that may hit the floor 9. Drop rear that engine is totally seated to your dolly. Note again: Check again if rotor is not hitting the floor. 10. Remove engine and tranny bolts. 11. Raise your rear car slowly and always check on top your engine bay to see if clearance are all okay. You may use 2 jack stand just for additional security but don’t forget to lower the floor jack every time you lower your rear until no enough space for the jack stand and you can just put them aside 12. Pull engine out |
| Tjmrfe |
Jun 12 2019, 09:43 AM
you’re almost there to drop your engine. For sure you can do it by yourself. Is your current lifter can drop your engine all the way down a furniture dolly and the highest to raise your car (rear valance) can get around 29”? so you can pull the engine. (engine and dolly height is around 28”) Or use 2 floor jack to raise and lower your rear car during the engine removal. I took off the rear valance, and was figuring that lowering the car down to the dolly, removing the bolts, and lifting the car away from the motor would be the safest. Thanks for the height info...I’ll have to see how high that lift gets. I’m pretty sure she’s gonna make it... |
Tjmrfe Could use a hand... Jun 12 2019, 09:23 AM
JOEPROPER I wish I had some time. I could use a drive over ... Jun 12 2019, 10:07 AM
rhodyguy I use the 2 jack method raising under the control ... Jun 12 2019, 10:34 AM
rgolia I think a group of 914 guys are meeting in Chester... Jun 12 2019, 01:23 PM
Big Len We'll figure out a way to help you out. PM you... Jun 12 2019, 02:54 PM
cuddy_k I’m in northern Westchester and am happy to come... Jun 12 2019, 03:03 PM
injunmort i'm free. lets do it before mid july, then you... Jun 12 2019, 04:02 PM
Big Len
i'm free. lets do it before mid july, then yo... Jun 12 2019, 04:58 PM
rhodyguy Problem solved!!! Great bunch of peopl... Jun 12 2019, 04:23 PM
Tjmrfe
Problem solved!!! Great bunch of peop... Jun 13 2019, 05:58 AM
dabird I grew up in Orange County, NY. This thread is mak... Jun 12 2019, 04:34 PM
rgalla9146 I saw Ian at Bear Mt. tonight and he mentioned you... Jun 12 2019, 07:57 PM
bigkensteele I do it by myself. I use a jack under the engine ... Jun 12 2019, 08:31 PM
Tjmrfe Wow, as expected, you guys couldn’t have been mo... Jun 13 2019, 05:26 AM
mepstein Get a Tangerine jack plate and make it an easy, on... Jun 13 2019, 05:39 AM
BeatNavy Most people only regret not buying one sooner.
... Jun 13 2019, 05:52 AM
Tjmrfe
Get a Tangerine jack plate and make it an easy, o... Jul 13 2019, 06:14 PM
IronHillRestorations +1 on the Tangerine engine plate, but you'd ne... Jun 13 2019, 06:45 AM
bdstone914 @Tjmrfe
I would be very interested to see if the... Jun 13 2019, 07:00 AM
cuddy_k
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 13 2019, 07:33 AM
VaccaRabite
[b]@[url=http://www.914world.com/bbs2/index.php?... Jun 13 2019, 10:30 AM
Tjmrfe
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 13 2019, 04:43 PM
Tjmrfe
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 13 2019, 06:17 PM
cuddy_k Actually...using the tall blocks that come with th... Jun 13 2019, 01:11 PM
Tjmrfe
Actually...using the tall blocks that come with t... Jun 13 2019, 02:34 PM
Bleyseng :popcorn: Jul 14 2019, 11:05 AM
SirAndy Bit late to the party but we do have a nice write-... Jul 14 2019, 11:23 AM
Tjmrfe
Bit late to the party but we do have a nice write... Jul 15 2019, 06:20 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:52 PM |
