| porschetub |
Jun 11 2019, 07:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,171 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Got the car out of storage for a startup and short drive yesterday,noticed the engagement point is high on the pedal (again),obviously isn't happy there,and not fun to drive this way.
Sometime back I shimmed the ball pivot as it was clear the throw out lever was contacting the gearbox casing...not by much but after measurement it appeared my flywheel had been resurfaced @ some stage but still in spec. Cable was new when I did the 6 conversion 708kms ago,and I cant find any movement in the tunnel tube,clutch is new and all wear parts replaced on the throw-out lever and bearing,have new 914rubber cable roller also. Really got me buggered this one ,why do I need to adjust it so often.....bad cable who knows. TIA |
| Rand |
Jun 12 2019, 02:35 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Every lurker is wondering if the firewall crack is a thing.
| porschetub |
Jun 12 2019, 03:07 PM
Every lurker is wondering if the firewall crack is a thing. No indication of that when last on a hoist to fix an oil leak,car has had little use since then except for running up the motor monthly. Keep the idea's coming however,I will make a checklist and go into it all,Perrys comment got me thinking about the dreaded roll pin ,nothing to say it hasn't broken after my pedal box rebush job (IMG:style_emoticons/default/confused24.gif) . (IMG:style_emoticons/default/beerchug.gif) |
porschetub Clutch adjustment issues ! Jun 11 2019, 07:28 PM
Spoke I went through about a month of clutch adjustments... Jun 11 2019, 07:35 PM
IronHillRestorations I've seen problems caused by a faulty roll pin... Jun 11 2019, 07:35 PM
porschetub Thanks for the replies folks ;
Spoke was the cable... Jun 11 2019, 10:12 PM
bdstone914 @ porschetub
' date='Jun 11 2019, 09:12 P... Jun 13 2019, 07:42 AM
rjames Is the nut loosening itself on the transmission en... Jun 12 2019, 12:27 AM
porschetub
Is the nut loosening itself on the transmission e... Jun 12 2019, 01:59 PM
rjames Double post Jun 12 2019, 12:27 AM
porschetub Thanks Bruce ,guess this should be rechecked as it... Jun 15 2019, 03:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th September 2026 - 05:00 PM |
