rnellums |
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains ![]() |
Hey all,
I've got some issues aligning my flared 914. With the drivers rear at the limit of travel I'm still quite a bit toe out. Measurements of the hub-pivot distance are a bit longer on the drivers vs. the passenger rear. the bend isn't visually noticeable, but its there. Has anyone had luck trueing it up or should I just find another trailing arm and move on? Thanks! -Ross |
rnellums |
Hey all, I've got some issues aligning my flared 914. With the drivers rear at the limit of travel I'm still quite a bit toe out. Measurements of the hub-pivot distance are a bit longer on the drivers vs. the passenger rear. the bend isn't visually noticeable, but its there. Has anyone had luck trueing it up or should I just find another trailing arm and move on? Thanks! -Ross I would think it would be easier, cheaper and faster to just get another used control arm if it is in fact bent. I would also check the inner control arm mount to make sure it is in the right location and is not cracked. Jeff B Easier - maybe, but ill have to swap over the hub, my polybronze bushings, and the bearings (if I can save them) Cheaper - maybe, but I'd have the cost of a new arm and shipping, likely a new rear bearing, potentially new polybronze bushings. it definitely adds up. Faster - agreed. I just had the suspension off and the inner mounts are good (and have additional bracing welded on). always a good idea to check though! I think TangeringeRacing (RacerChris) can help you out with that. Or roll the dice on a used one and hope it's not bent either. That was kind of my thinking. there is a decent chance I buy and arm and it arrives bent too. Probably ought to give Chris a call. |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
I think TangeringeRacing (RacerChris) can help you out with that. Or roll the dice on a used one and hope it's not bent either. That was kind of my thinking. there is a decent chance I buy and arm and it arrives bent too. Probably ought to give Chris a call. (IMG:style_emoticons/default/agree.gif) Chris can likely sell you a known straight arm at the least since he has jigging to check. |
Lo-Fi Version | Time is now: 16th June 2024 - 03:12 PM |
