QUOTE(jkb944t @ Jun 14 2019, 09:28 AM)
QUOTE(rnellums @ Jun 14 2019, 12:23 PM)
Hey all,
I've got some issues aligning my flared 914. With the drivers rear at the limit of travel I'm still quite a bit toe out. Measurements of the hub-pivot distance are a bit longer on the drivers vs. the passenger rear.
the bend isn't visually noticeable, but its there. Has anyone had luck trueing it up or should I just find another trailing arm and move on?
Thanks!
-Ross
I would think it would be easier, cheaper and faster to just get another used control arm if it is in fact bent.
I would also check the inner control arm mount to make sure it is in the right location and is not cracked.
Jeff B
Easier - maybe, but ill have to swap over the hub, my polybronze bushings, and the bearings (if I can save them)
Cheaper - maybe, but I'd have the cost of a new arm and shipping, likely a new rear bearing, potentially new polybronze bushings. it definitely adds up.
Faster - agreed.
I just had the suspension off and the inner mounts are good (and have additional bracing welded on). always a good idea to check though!
QUOTE(TravisNeff @ Jun 14 2019, 09:29 AM)
I think TangeringeRacing (RacerChris) can help you out with that. Or roll the dice on a used one and hope it's not bent either.
That was kind of my thinking. there is a decent chance I buy and arm and it arrives bent too. Probably ought to give Chris a call.
