> Clutch adjustment issues !, needs to be adjusted again..something wrong ?
porschetub
post Jun 11 2019, 07:28 PM
Got the car out of storage for a startup and short drive yesterday,noticed the engagement point is high on the pedal (again),obviously isn't happy there,and not fun to drive this way.
Sometime back I shimmed the ball pivot as it was clear the throw out lever was contacting the gearbox casing...not by much but after measurement it appeared my flywheel had been resurfaced @ some stage but still in spec.
Cable was new when I did the 6 conversion 708kms ago,and I cant find any movement in the tunnel tube,clutch is new and all wear parts replaced on the throw-out lever and bearing,have new 914rubber cable roller also.
Really got me buggered this one ,why do I need to adjust it so often.....bad cable who knows.
TIA
porschetub
post Jun 15 2019, 03:30 PM
Thanks Bruce ,guess this should be rechecked as it was a while ago ,it could have broken away since then ?.
My cable is a Gemo brand I got from Pelican,will report back when I get time to do it, (IMG:style_emoticons/default/beerchug.gif) .
- Lo-Fi Version Time is now: 18th September 2026 - 05:02 PM
