Pulling Stub axle, Into bearings |
shane |
Jun 15 2019, 07:01 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
Hi, I have my new rear bearings in and was going to pull my wheel hubs in by using my CV joint stub axles. My CV axles are hooked to the trans and I have the stub axle through the inside of the bearing. I previously watched this video https://youtu.be/lnXdjTate5o and in it the guy uses his castle nut to put the stub axle through the inside of the bearing. Problem is my stub axle doesn’t come out through the inside of the bearing far enough to put the cast but on let alone the washer and the cast nut. Am I missing something?
Lo-Fi Version | Time is now: 16th June 2024 - 06:55 AM |
