QUOTE(shane @ Jun 16 2019, 01:04 PM)
Now that I have my drive axles inner CV joint bolted to the trans and can’t use the stub axle side to pull my wheel hub in, I’m going to have to pull the drive axle back out. I don’t suppose there is any way to separate the CV joint from the trans without destroying the paper gasket? Sometimes watching other people’s videos and there techniques that mysteriously work for them lead you down a bad road. Should have first made sure it was possible before I started to copy the video
can order more gaskets Just was hoping to finish that task today.
The gaskets are not likely to survive.
They can survive if you don't mind leaving chisel marks on your inside CVs
Aim the chisel away from the flange into the outside surface of the CV...
NOT into the gasket groove. Alternate between sides at the roll pin area
Are your heat exchangers on ?
