| R Dub |
Dec 3 2017, 02:34 PM
Member ![]() ![]() Group: Members Posts: 126 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
Finally got the car back to IL and started to clean it up. Overall he car is in really good shape. There is virtually no rust on it. Just a very little bit starting to form on the front fender by the hood. The paint is in really good condition but will probably need a new paint job as there are some chips in that that won't be able to touch up since it is 30+ years old. Will need the Recaro seats to be redone and will need a new arm rest. Drained the old gas out of it and then drained the oil which was mostly sludge. Bought sludge remover and put that in the case to help break it up. The mice ate the plug wires and the battery is totally shot. What spark plugs and wires do you guys recommend?
Here are a few picture. (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.5.jpg) |
| R Dub |
Jun 15 2019, 08:53 PM
Update. Put the new relay in and fuel pump seemed to work great. Hopefully that fixed that issue.
Took the carb off and found out that the roll pin came out of the cam and was not lifting the lifter. Therefore as a result it was not squirting fuel. Put a new roll pin in there and it fixed that issue. Then got the car running and pretty well. Adjusted the timing and everything seemed to be running good but then.... Went to turn the car around on the lift so the back was facing the garage door so we could run the car for a while to dial in the carbs. While driving up, the external oil cooler drain bolt hit the lift and cracked the housing and oil started to leak everywhere. Honestly my grandpa had all of the external oil cooler lines run pretty poorly so I will now have to redo all of them. Below is a pic. Now I Need Help! 1) I need to know where does the oil temp sender wire plugs into under the battery? I looked everywhere and couldn't find it. The wiring is not stock so I'm sure that doesn't help 2) At idle the volts is just under 12 and then when you hit the brakes or turn signal it drops to under 10. Is this normal? If not, what should it be and how do I tell if the alternator is bad or something else? If something else, where to start? (IMG:http://www.914world.com/bbs2/uploads_offsite/i.ibb.co-21387-1560653615.1.jpg) |
R Dub 73 914 2.0 Rebuild Dec 3 2017, 02:34 PM
Olympic 914 Slantnose looks nicely done. Dec 3 2017, 05:07 PM
krazykonrad :wttc:
The general consensus is that the origina... Dec 4 2017, 09:18 AM
R Dub
:wttc:
The general consensus is that the origin... Dec 4 2017, 11:54 AM
mgphoto Beru another OEM supplier. Dec 4 2017, 12:25 PM
The Cabinetmaker Most folks use ngk plugs and beru wires Dec 4 2017, 12:44 PM
R Dub Just bought a set of Beru Wires and Bosch plugs fr... Dec 4 2017, 03:18 PM
mgphoto Battery recommendation AGM, no free acid, prevents... Dec 4 2017, 04:01 PM
R Dub
Battery recommendation AGM, no free acid, prevent... Dec 4 2017, 04:52 PM
Larmo63 Those seats look like Scheels. Are they marked Rec... Dec 4 2017, 10:11 PM
burton73
Those seats look like Scheels. Are they marked Re... Dec 4 2017, 10:49 PM
R Dub I was told by my dad and Grandpa that they are Rec... Dec 10 2017, 01:53 PM
R Dub Update. Actually got the car running to day. First... Feb 17 2018, 09:17 PM
burton73 It there snow on the ground there.
Stay dry my fr... Feb 17 2018, 10:02 PM
burton73 This is a Konig driver's seat, but sure looks ... Feb 17 2018, 10:05 PM
R Dub
I looked up you seats and I think they are Koni... Feb 19 2018, 09:43 AM
Porschef I've got the same wheel on my car, your horn b... Feb 18 2018, 08:22 AM
R Dub
I've got the same wheel on my car, your horn ... Feb 19 2018, 09:44 AM
R Dub Looking for some parts advice.
1. Right under the... Feb 19 2018, 09:50 AM
marksteinhilber
1. Right under th... Jan 10 2019, 12:05 PM
fishgeckos I like the rear spoiler. Feb 19 2018, 10:06 AM
R Dub A couple of questions. As I mentions this car does... Feb 26 2018, 01:01 PM
R Dub Just a quick update, I found a place in CA called ... Mar 16 2018, 05:48 PM
R Dub Haven't posted in a while cause I haven't ... Jun 19 2018, 12:43 PM
rjames
Haven't posted in a while cause I haven't... Jun 19 2018, 05:03 PM
rhodyguy Go to the classic thread forum. The easy method to... Jun 19 2018, 05:18 PM
R Dub Got the fuel pump figured out but found out that o... Nov 11 2018, 07:35 PM
Mblizzard
Got the fuel pump figured out but found out that ... Nov 12 2018, 10:19 AM
R Dub
You can go the AA Piston route for P/Cs for abou... Nov 12 2018, 01:49 PM
Mblizzard
[quote name='Mblizzard' post='2664984' date='Nov ... Nov 13 2018, 11:43 AM
Tdskip Good morning. Not to discourage your asking quest... Nov 13 2018, 07:27 AM
TheCabinetmaker What Td said. Do your search on Google, then add t... Nov 13 2018, 11:29 AM
bbrock And make sure you are settled on your fuel system ... Nov 13 2018, 12:18 PM
R Dub I'm going to keep the car with the dual Webers... Nov 13 2018, 04:49 PM
R Dub Engine out
[img]http://www.914world.com/bbs2/uplo... Jan 9 2019, 07:49 PM
mgphoto
1 motor is no longer stock, if it was then yes l... Jan 10 2019, 05:21 PM
R Dub
1 motor is no longer stock, if it was then yes le... Jan 10 2019, 06:39 PM
mgphoto
1 motor is no longer stock, if it was then yes l... Jan 11 2019, 01:37 PM
R Dub
I built mine with parkerized solid lifters and h... Jan 12 2019, 05:19 PM
Bleyseng
I built mine with parkerized solid lifters and ... Jan 27 2019, 04:33 PM
steuspeed No reason to stick with 2.0L. Go for more power. I... Jan 9 2019, 08:05 PM
mgphoto Pull the oil pump, look inside, if the cam gear ha... Jan 10 2019, 05:04 PM
mgphoto Hydraulic lifters, bad... Jan 10 2019, 05:06 PM
bbrock There are several threads on the swivel foot adjus... Jan 12 2019, 11:10 PM
R Dub
There are several threads on the swivel foot adju... Jan 13 2019, 04:24 PM
R Dub Just found this on aircooled.net about the 911 adj... Jan 13 2019, 04:43 PM
mgphoto My advice is that you should pick up the Wilson VW... Jan 14 2019, 02:16 PM
R Dub Just ordered about $630 worth of seals from 9... Jan 27 2019, 03:36 PM
Valy That crack needs some head welding.
Sorry for the ... Jan 28 2019, 12:00 AM
R Dub Quick update:
The heads are with Adrian at Headfl... Mar 5 2019, 02:23 PM
R Dub Starting to get some parts in. I was told the head... Mar 23 2019, 03:29 PM
R Dub Dropped the motor off with McMark at Original Cust... Mar 31 2019, 03:13 PM
R Dub Got the motor back from McMark a couple weeks ago.... Jun 11 2019, 12:17 PM
R Dub Today was a great day. Got the oil cooler lines al... Jun 23 2019, 08:57 PM
R Dub Been two months since I brought the car home. I dr... Aug 24 2019, 08:57 PM
Larmo63 Your turn signal switch is probably broken or worn... Aug 25 2019, 06:34 PM
R Dub Unfortunately the car has been put away for the wi... Oct 22 2019, 05:24 PM
R Dub Got the interior torn apart. Now I need some help ... Dec 24 2019, 12:43 PM
timothy_nd28 Yes, the old light bulbs are not used anymore when... Dec 30 2019, 01:00 PM
R Dub Quick update. The interior is at the shop. Seats, ... Jan 15 2020, 06:18 PM
R Dub Just picked this up from the interior guy today. T... Jan 18 2020, 02:31 PM
R Dub Had some goodies arrive. Got a new Bluetooth head ... Jan 25 2020, 03:48 PM
R Dub Got to spend some time on the car today. Got the L... Jan 26 2020, 07:58 PM
R Dub Dash is done. And here a little teaser if the seat... Feb 1 2020, 11:41 AM
R Dub Seats are done. What a difference. Start to put th... Feb 28 2020, 09:43 PM
R Dub Good news and bad news.
Good news is got the int... Apr 26 2020, 08:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:55 AM |
