| bbrock |
Mar 20 2019, 08:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I didn't want to hijack the other thread but have a question about my own Webers. They are Italian 40IDFs I bought in the late 80s or early 90s. Other than finger tight bolting them on to my engine to see how cool they looked, they have never been used. No fuel has touched them. I don't remember if I even opened them to set the float levels. BUT... they were stored in a humid basement for several years before I moved to a civilized climate. So, the magnesium housing is tarnished on the outside and the plating has deteriorated on a few of the levers and such. Pretty minor stuff from what I can see.
My question: is there is anything special I should do or check other than inspecting for corroded parts and normal setup as I prep these for service? |
| IronHillRestorations |
Jun 20 2019, 06:53 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,959 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Here's my carb tuning procedure from a March 03 post:
Assumptions: the carbs have the optimum jet and venturi package (if you have an unknown engine/cam good luck on this one), the float level in the carbs is correct, the cams are correctly timed, the valves are properly adjusted, the ignition timing is dead on, you have the proper spark plugs for your engine, the linkage is good, the fuel is good, the engine is good. Remember that the mixture and air bypass adjustment screws are precision needle valves, not head gaskets. Use your fingers to tighten them, not your fist. Start and warm up the engine. Make sure the two drop links for the throttle linkage are exactly the same length, and disconnected. You can use a 8mm thin ignition wrench to snap them off. Turn the mixture screws all the way in and then 5 half turns out. Turn the air bypass screws all the way in. Turn the idle speed screws out til it just touches, and then in 3 half turns. (3 barrels I go 5 half turns) Put on your hearing protection and start the car. Use your STE and find the barrel that pulls the most. We'll call this one baseline. Balance the barrel in the other carb that pulls the most with the idle speed screw. (if you have a Uni-syn, give it to someone you don't like and purchase a STE airflow meter) Go back to the other carb, with the baseline barrel. You will have one all the way in, then use the air bypass screws and balance the other two barrels. Go to the other carb and do the same thing. Snug the jamb nuts on the air bypass screws. All six barrels should pull the same amount of air at this point, if not repeat air adjustment procedure. Snap the throttle linkage drop links back on the carbs. If the idle changes then you need to barely adjust the linkage mounts so snapping the drop links on, doesn't change the side to side idle balance. Use the hand throttle or a vice grip and rag to lock the linkage between 1400 and 1800 rpm. Start back at the baseline barrel and adjust the mixture screw in or out, to get the smoothest running and highest idle, then turn it in 1/4 turn. Do the same with the five other mixture screws. If you have to turn the mixture screws more than two turns either way (from baseline), you've got the wrong jets. Recheck side to side and individual air balance, adjust as needed. Road test the car. If you get snapping and poping out the intake, it's generally a lean condition. If you get heavy exhaust fumes, or pboofing out the exhaust it's probably too rich. If you get a flat spot or popping out the intake at between 2800 and 3200 rpm, you probably need larger idle jets. That's a rough, five minute draft of my carb tuning proceedure, hope it helps! If it goes good it should take about 45 minutes, if not about three years. PK If it's running good but a little rich, you can turn each air bypass screw out to lean it out some, go a half turn out at a time and test drive. Make sure you turn all screws the same amount. This was written 16 years ago before wide band O2 sensors were economical and easy to install, get one it will make your carb tuning much easier. |
bbrock Reviving NOS Webers Mar 20 2019, 08:55 PM
914_7T3 Are you really going to go through with it? After... Mar 20 2019, 09:47 PM
bbrock
Are you really going to go through with it? Afte... Mar 21 2019, 08:13 AM
MarkV If nothing else I would take them apart and do a t... Mar 20 2019, 10:07 PM
Mark Henry :agree: take them apart, clean, blow out*, etc.
C... Mar 21 2019, 05:57 AM
rgalla9146
... Mar 21 2019, 06:04 AM
Superhawk996 Be brave. Put on and see what they do.
If store... Mar 21 2019, 07:45 AM
tmessenger The float needle tip can harden with age so I repl... Mar 21 2019, 07:53 AM
Superhawk996 Just to add a little more context.
My car had b... Mar 21 2019, 07:56 AM
Superhawk996 Not trying to start a :stromberg: storm but I do... Mar 21 2019, 08:04 AM
tmessenger Here's a photo of the needle that came out of ... Mar 21 2019, 09:15 AM
dr914@autoatlanta.com Richard at PMO is a great sounding board for any w... Mar 21 2019, 09:28 AM
bbrock
The float needle tip can harden with age so I rep... Mar 21 2019, 08:21 AM
Superhawk996 :worship:
I learned something. Thank you.
My... Mar 21 2019, 09:37 AM
Chi-town You'll want to replace all the original rubber... Mar 21 2019, 09:55 AM
MarkV If you are putting them on a fresh engine with fre... Mar 21 2019, 08:13 PM
Superhawk996
If you are putting them on a fresh engine with fr... Mar 22 2019, 10:13 AM
bbrock
Bottom line: Brent is fastidious and his attenti... Mar 22 2019, 11:46 AM
Superhawk996 :unsure:
Wow. I'm looking for the eating c... Mar 22 2019, 12:34 PM
bbrock
:unsure:
Wow. I'm looking for the eating ... Mar 22 2019, 12:42 PM
timothy_nd28
:unsure:
Wow. I'm looking for the eating... Mar 22 2019, 02:33 PM
bbrock
Basement walls sweating is not a good thing at al... Mar 22 2019, 03:00 PM
porschetub
:unsure:
Wow. I'm looking for the eating ... Sep 6 2020, 02:17 AM
Superhawk996 How about this one
I got :owned: Mar 22 2019, 12:37 PM
Tdskip
How about this one
I got :owned:
Nah - your as... Jun 20 2019, 07:18 AM
How about this one
I got :owned:
Nah - your a... Jun 20 2019, 07:35 AM
johnhora Brent,
Those are in good shape for the age and am... Mar 22 2019, 12:40 PM
bbrock
Brent,
Those are in good shape for the age and a... Mar 22 2019, 12:50 PM
Superhawk996 I'm in Detroit and we get lots of humidity but... Mar 22 2019, 12:50 PM
johnhora Pierce Manifold is very good as are others..
https... Mar 22 2019, 01:08 PM
MarkV My DRLA 40's have some of that white staining ... Mar 22 2019, 02:07 PM
bbrock
Not sure why they came with 28's.... they mig... Mar 22 2019, 02:23 PM
MarkV
Not sure why they came with 28's.... they mi... Mar 22 2019, 02:44 PM
rhodyguy As noted, the 40s would have come with 28mm Ventur... Mar 23 2019, 08:15 AM
bbrock More good info guys. I appreciate it. This is ma... Mar 23 2019, 08:36 AM
Superhawk996 Back in the day (meaning when I was younger and le... Mar 23 2019, 09:30 AM
porschetub 28mm vents will work fine,they will offer a great ... Mar 23 2019, 02:59 PM
bbrock I finally got around to this project. I have the ... May 21 2019, 08:22 PM
mepstein If you send them to me, I'll vapor blast them ... May 21 2019, 09:08 PM
bbrock
If you send them to me, I'll vapor blast them... May 22 2019, 07:26 AM
72hardtop At your altitude stay with the 28mm vent size comb... May 30 2019, 02:42 PM
bbrock
At your altitude stay with the 28mm vent size com... May 31 2019, 09:13 AM
porschetub
At your altitude stay with the 28mm vent size com... Jun 1 2019, 12:24 AM
bbrock Carbs are finally cleaned up and back together. T... Jun 19 2019, 10:18 AM
rhodyguy Get the CB Weber manual. 2056? Refresh my memory. ... Jun 19 2019, 10:55 AM
bbrock
Get the CB Weber manual. 2056? Refresh my memory.... Jun 19 2019, 11:11 AM
rhodyguy OK, the 28s should be fine. A little short on the ... Jun 19 2019, 11:19 AM
ThePaintedMan Nice job. :headbanger: Highly recommend you spra... Jun 20 2019, 02:23 PM
bbrock
Nice job. :headbanger: Highly recommend you spr... Jun 20 2019, 02:34 PM
72hardtop What elevation you at? (My jetting is a few hundre... Sep 6 2020, 01:26 AM
IronHillRestorations I went back and re-read some of this thread. I... Sep 6 2020, 11:50 AM
bbrock
I went back and re-read some of this thread. I... Nov 22 2020, 07:13 PM
bbrock I was surprised to see this old thread pop up agai... Sep 6 2020, 12:17 PM
72hardtop My procedure....
Ma... Nov 2 2020, 06:19 AM
Gint I've had this thread open in a browser tab on ... Nov 21 2020, 09:09 AM
nditiz1 I haven't ever converted them to disabled as t... Nov 22 2020, 08:10 PM
bbrock
I haven't ever converted them to disabled as ... Nov 22 2020, 08:26 PM
914werke Interesting, I happen to be working on a customers... Aug 19 2021, 02:23 PM
Interesting, I happen to be working on a customer... Aug 20 2021, 04:47 AM
914werke If they were mine I might take this approach, but ... Aug 20 2021, 07:52 AM
IronHillRestorations I've never seen the cold start enrichment used... Aug 20 2021, 12:18 PM
914werke I've never seen the cold start enrichment use... Aug 21 2021, 11:58 AM
bbrock At one point I had plans to add a 914-6 throttle l... Aug 21 2021, 12:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 12:16 AM |
